Hi Partha.
taking advantage of this post, I would like that the API also contains the projectionObjectsCollection in a profileView class.
Other properties for a projectionObject should be: source type entity, source location, elevation type, station projected object, elevation projected object.
I want to do a command but I need the collection from each profile view, and I need to know the source location because I want to select an AutoCAD point in plant, show a datagrid within a form.
this datagrid will show all the avaiable profile views which contain it projected object and finally, according to the selected row in the dgv, the command will do zoom to the projected object in the selected profile view.
I think that Civil 3d would already have this function!
Moreover, the projection tab in the profile view is very poor.poor.ther is no information(only read) about:te station in case if the source object was Autocad point or COGO, source entity type, description.
That table should allow to be sorted such as by station .
and I think that the tab should be in a palette!
Regards.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
