New to C3D .net, long time C3D user. Guess I thought I would take matters into my own hands and really pop the hood. So I've managed to create a Survey Project, Network, Points, Figures, Alignment, and a Profile with a view; all from a couple of xml files of survey data. All right that's all going well enough.
I need to project some of the points and figures to the profile view and I'm not making any progress. I found the ProfileProjection class in the object browser, but I'm not sure how to handle the first argument (ByVal unmanagedPointer AsSystem.IntPtr,) or even if I'm on the right path. I'm guessing that it should work similar to other Create() methods by referencing an ID, then later calling a projObject.Draw() or something similar. An example would be great.
Below is a snippet of the survey point section. I'm iterating through each survey point in the xml data. I hope to create the projObj for each CL shot as a starting place. I think the figures would be similar if I can get a point to work.
Using C3D 2012
'Survey Points ================================================================ 'Create Non-Control Points for network Dim oNonControlPt As AeccSurveyNonControlPoint 'Dim xNumber As Integer = 0 For Each xPoint In pFile...<Point> Dim xNumber As Integer = xPoint.<Number>.Value Dim xName As String = xPoint.<Name>.Value Dim xDescription As String = xPoint.<Code>.Value Dim xEast As Double = xPoint.<Grid>.<East>.Value / 3.28083333333333 Dim xNorth As Double = xPoint.<Grid>.<North>.Value / 3.28083333333333 Dim xElevation As Double = xPoint.<Grid>.<Elevation>.Value / 3.2808333333333 oNonControlPt = oSurveyNetwork.NonControlPoints.Create( _ xNumber, xName, _ xDescription, _ xEast, _ xNorth, _ xElevation) Dim projPointID As System.IntPtr = oNonControlPt.ID 'Fatal Error Here!!!! If oNonControlPt.Description.Contains("CL") Then 'project each CL point to profile Dim projObject As ProfileProjection = ProfileProjection.Create(projPointID, False) End If Next '?oSurveyNetwork.UpdateNetwork() 'Survey Figures ================================================================
Any help or direction will be appreaciated.
Eric
Solved by Partha.Sarkar. Go to Solution.
Hi Eric,
Please refer to the Civil 3D .NET API Ref document, ProfileProjection class has only few properties exposed, create() is not exposed for public usage, sorry.
Few years ago I had written the following VBA code which will draw a point on a selected location on the surface and then project the same point in the Profile View (long profile). I think you can use this concept and use the .NET API now to project the objects to Profile View.
Public Sub DrawPointInProfileView()
Dim oApplication As AcadApplication
Set oApplication = ThisDrawing.Application
Const sAppName = "AeccXUiLand.AeccApplication"
Set g_oCivilApp = oApplication.GetInterfaceObject(sAppName)
Set g_oAeccDoc = g_oCivilApp.ActiveDocument
Set g_oAeccDb = g_oAeccDoc.Database
' Select an Alignment
' Select a point on the surface and find out the Station with respect to an Alignment
Dim oPoint As AeccPoint
Dim objEnt As AeccAlignment
Dim varPick As Variant
ThisDrawing.Utility.GetEntity objEnt, varPick, "Select an Alignment "
If objEnt Is Nothing Then
Exit Sub
ElseIf TypeOf objEnt Is AeccAlignment Then
Dim pt As Variant
Dim stn As Double, off As Double
Dim oSurf As AeccSurface
Dim dElevationAtPoint As Double
Set oSurf = g_oAeccDb.Surfaces.Item(0)
pt = ThisDrawing.Utility.GetPoint(, "Select the Point")
dElevationAtPoint = oSurf.FindElevationAtXY(pt(0), pt(1))
objEnt.StationOffset pt(0), pt(1), stn, off
pt(2) = dElevationAtPoint
MsgBox "Station = " & stn
MsgBox "Elevnation of Selected Point = " & pt(2)
ThisDrawing.SetVariable "PDMODE", 34
Set oPoint = g_oAeccDb.Points.Add(pt)
MsgBox " Point is Drawn at Selecetd Location"
Else
Exit Sub
End If
' select the Profile View where you want to Project the Point
Dim acadObj As AcadObject
Dim pnt As Variant
Dim oProfileView As AeccProfileView
ThisDrawing.Utility.GetEntity acadObj, pnt, "Select a Profile View"
If acadObj Is Nothing Then
Exit Sub
ElseIf TypeOf acadObj Is AeccProfileView Then
Set oProfileView = acadObj
Else
Exit Sub
End If
On Error Resume Next
MsgBox " Profile View Name = " & oProfileView.Name
Dim x As Double, y As Double
oProfileView.FindXYAtStationAndElevation stn, dElevationAtPoint, x, y
Dim point As AcadPoint
Dim location(0 To 2) As Double
location(0) = x
location(1) = y
location(2) = 0#
' Create the point in Profile View
Set point = ThisDrawing.ModelSpace.AddPoint(location)
MsgBox " Point is Drawn in Profile View "
End Sub
Does it help ?
It took me a while to get back to working on this issue, but I've got so much help from the groups that I wanted to post reply. So, yes the vba code did lead me to the answer Partha, thanks.
As implemented in my code for vb.net. I'm labeling a filtered set of survey points on the profile. Here I'm in a For Each statement using linq with a xml file. Below I'm using the similar StationOffset to get the plan station value and offset from the X, Y values of the points.
'Return the station and offset for the current point currentAlignment.StationOffset(xEast, xNorth, 0.25, planStaVal, planOffVal)
'Return the profile view's current X,Y equilivant for a given station and elevation oProfileView.FindXYAtStationAndElevation(planStaVal, minElev, lblPOTx, lblPOTy)
The one issue I have with this solution is the text, lines, blocks, etc I've drawn on the profile aren't relative or dynamic to the profile view. So if the view moves or even the style gets changed the entities are disconnected and must be redrawn. I haven't put in place a solution for that yet.
Would anyone care to recommend a suggestion to "bind" these entities to the view?
I've thought about maybe grouping them all or maybe putting xData on each item to reference back to the start of the profile or a known Station, Elevation tic.
I am glad to know that it was helpful to you.
Text, Lines, blocks are not part of Civil 3D object family and hence are not dynamic. Could you consider them replacing with Civil 3D objects Like Lables, Feature Line etc. ?
Partha
Even if the points were cogo. they will not reflect change on plan dynamically.
Just drawing points on the profile is far from what i'd call a solution.
I wish we had a method to project objects to profile view..
I cant even use SetImpliedSelection() to a Doc.SendStringToExecute("ProjectObjectsToProf", True, False, True)
becuase you have to select the profile 1st.
no resolution here?
Hi Eric,
if you have to project basic AutoCAD entities to specific plane then you can use following function:
Autodesk.AutoCAD.DatabaseServices.Curve.GetProjectedCurve
it returns circle, ellipse or line against to the specific plane depends on entity figure and direction.
-Veli
