alignment properties-tab "design rules".
Can I know the variable "speed project" and its station project?
Can I know the value (text) specified in "minimum radius table" and "sobreelevation setting method"?
I need the variables for programming in C#.
I would make an application form the Spanish alignment and Profiles rules.
See the screenshoot.
Thank you.
Hi joantopo,
Please look into the following in Civil 3D .NET API -
Alignment.DesignSpeeds Property -> Gets the Alignment design speed collection.
DesignSpeedCollection.GetDesignSpeed Method -> Gets the DesignSpeed object in the collection by raw Station value.
Does it help ?
ok. Iit´s right.
Thank you.
But where is the property "MinimumRadiusTableName"? for DesignCriteria
I would like get this property.
it exist for AutoWideningDesignCriteria.
I don't see 'MiniumRadius Table' is exposed for Alignment object, however, you can use the Alignment.CriteriaFileName API and get the design criteria XML file and read the value from there.
Does it help ?
Yes, but it is not a solution for me. There exist 2 groups (2 tables) in the XML (spanish rules), and I want to know which the user chooses, from the properties of alignment.
At the moment, I will put a combobox with these 2 options of table, but I had liked to obtain the value of this form.
I hope that it appears in some API's new version
Trank you.
