I've got a Profile View style set up just the way I want it. The only problem that I have is that the automated fill hatch that I'm using between my existing and finish profiles is showing up behind the grid lines. Unfortunately, we use "lines overwrite" as a standard, so I can't just switch to "lines merge". Does anyone know of a way or a setting that would allow me to move the draw order of the fill hatch above the grid lines?
Hi Ben,
Is this something you are trying to achieve using Civil 3D UI ? That's what I understand from the description you gave here and I presume you are not using API here. If this is related to Civil 3D UI tools / commands, I would suggest to post the same to Civil 3D user group and you might get a prompt response as most of the Civil 3D users are active in that group compared to this one, where mostly programmers participate. If I have misunderstood and you are using Civil 3D API, please confirm and upload a DWG file / screenshot highlighting what you are trying to get.
Partha
