Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Profile View Band Styles
6 REPLIES 6
Civil3DReminders_com
1546 Views, 6 Replies
I'm stuck. I'm trying to add assign a Pipe Network to a profile view Band in Civil 3D 2011. I was using COM to add profiles to bands because I couldn't figure out how to do it in .NET. But when it comes to pipe networks I don't see how you can do that with COM. Does anyone have some code for how the .NET implementation is supposed to work? Here's the code I have that works for COM, except for the pipe networks. I essentially need to assign the correct pipe network to the band.
Thank you,
        public static void AddProfileToBand(this ProfileView profileView, ObjectId profObjId, List<BandItemInfo> bandStyleInfosFromSet, ObjectId profileBandSetId)
            using (Transaction tr = Application.DocumentManager.MdiActiveDocument.TransactionManager.StartTransaction())
                try
                    Alignment align = profileView.AlignmentId.GetObject(OpenMode.ForRead) as Alignment;
                    AeccAppConnection aecApp = new AeccAppConnection();
                    AeccAlignment alignCOM = aecApp.AeccDoc.AlignmentsSiteless.Item(align.Name);
                    AeccProfileView profViewCOM = alignCOM.ProfileViews.Item(profileView.Name);
                    Profile prof = profObjId.GetObject(OpenMode.ForRead) as Profile;
                    AeccProfile profCOM = alignCOM.Profiles.Item(prof.Name);
                    // Remove the existing bands.
                    while (profViewCOM.BandSet.Count > 0)
                        profViewCOM.BandSet.Remove(0);
                    profileView.UpgradeOpen();
                    profileView.Bands.ImportBandSetStyle(profileBandSetId);
                    // Add them back in, this is if the user hasn't added them in.
                    //foreach (var bandStyleInfo in bandStyleInfosFromSet)
                    //    try
                    //        AeccBandStyle bandStyleCom = null;
                    //        switch (bandStyleInfo.BandStyleType)
                    //            case BandStyleType.HorizontalGeometry:
                    //                bandStyleCom = aecApp.AeccDb.ProfileViewBandStyles.HorizontalGeometryBandStyles[bandStyleInfo.Name] as AeccBandStyle;
                    //                break;
                    //            case BandStyleType.PipeNetwork:
                    //                // Not present in COM????
                    //                ObjectId bandStyleObjId = GetPipeNetworkBandStyleObjId(bandStyleInfo.Name);
                    //                BandStyle bandStyle = bandStyleObjId.GetObject(OpenMode.ForRead) as BandStyle;
                    //                bandStyleCom = bandStyle.AcadObject as AeccBandStyle;
                    //                break;
                    //            case BandStyleType.ProfileData&colon;
                    //                bandStyleCom = aecApp.AeccDb.ProfileViewBandStyles.ProfileDataBandStyles[bandStyleInfo.Name] as AeccBandStyle;
                    //                break;
                    //            case BandStyleType.SuperelevationData&colon;
                    //                bandStyleCom = aecApp.AeccDb.ProfileViewBandStyles.SuperElevationBandStyles[bandStyleInfo.Name] as AeccBandStyle;
                    //                break;
                    //            case BandStyleType.VerticalGeometry:
                    //                bandStyleCom = aecApp.AeccDb.ProfileViewBandStyles.VerticalGeometryBandStyles[bandStyleInfo.Name] as AeccBandStyle;
                    //                break;
                    //            default:
                    //                break;
                    //        if (bandStyleCom != null)
                    //            profViewCOM.BandSet.Add(bandStyleCom, alignCOM, profCOM, profCOM);
                    //        else
                    //            Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
                    //            ed.WriteMessage("\nError in adding band to profile view: " + bandStyleInfo.Name + "\n");
                    //    catch (Exception ex)
                    //        ed.WriteMessage("\nError in adding band to profile view: " + ex.Message + "\n");
                    foreach (AeccProfileViewBandSetItem band in profViewCOM.BandSet)
                        try
                            if (HasName(bandStyleInfosFromSet, band.BandStyle.Name) && band.BandStyle.Type == AeccBandStyleType.aeccProfileDataBandStyle)
                                band.Profile1 = profCOM;
                        catch (Exception)
                    tr.Commit();
                catch (System.Exception ex)
                    ed.WriteMessage("\nError in adding profile to band: " + ex.Message + "\n");
        private static bool HasName(List<BandItemInfo> bandStyleInfosFromSet, string name)
            return (bandStyleInfosFromSet.Where(x => x.Name == name).Count() > 0);
        private static ObjectId GetPipeNetworkBandStyleObjId(string name)
            CivilDocument civDoc = CivilApplication.ActiveDocument;
            ObjectId bandStyleObjId = civDoc.Styles.BandStyles.ProfileViewPipeNetworkBandStyles.Where(x => (x.GetObject(OpenMode.ForRead) as BandStyle).Name == name).FirstOrDefault();
            return bandStyleObjId;
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
6 REPLIES 6
Well I finally figured it out, one has to Set the ProfileViewBandItems after Getting it and then adding the profile or data source.
http://blog.civil3dreminders.com/2013/03/modifying-profile-view-bands.html
Civil Reminders
Hi @Civil3DReminders_com,
I have the same problem with bandset for sectionview.
Did you have import bandset for sectionview?
I use this medthod: sectionView.Bands.ImportBandSetStyle(bandstyle.Id);
it work well in Civil 3d 2023, but another version, it doesn't work.
Can you help me to sovled it?
c# tip 🙂
HasName method
            return bandStyleInfosFromSet.Any(x => x.Name == name);
I think the API change was made in Civil 3D 2020 Update 5. This is the only code that I've been using for updating the section view bands.
Civil Reminders
Hi @Civil3DReminders_com ,
Can you share me the function of "UpdateBandProfileAndDataSource" as picture below?
Thank you!
This is the one I found first.
        private static void UpdateBandProfileAndDataSource(ObjectId PipeNetworkObjId, Profile prof, ProfileViewBandItemCollection bottomBandItems, ObjectId prof2ObjId)
            foreach (ProfileViewBandItem bandItem in bottomBandItems)
                switch (bandItem.BandType)
                    case Autodesk.Civil.BandType.HorizontalGeometry:
                        bandItem.Profile1Id = prof.ObjectId;
                        if (!prof2ObjId.IsNull)
                            bandItem.Profile2Id = prof2ObjId;
                        break;
                    case Autodesk.Civil.BandType.PipeNetwork:
                        if (PipeNetworkObjId != ObjectId.Null)
                            bandItem.DataSourceId = PipeNetworkObjId;
                        break;
                    case Autodesk.Civil.BandType.ProfileData:
                        break;
                    case Autodesk.Civil.BandType.SectionData:
                        break;
                    case Autodesk.Civil.BandType.SectionSegment:
                        break;
                    case Autodesk.Civil.BandType.SectionalData:
                        break;
                    case Autodesk.Civil.BandType.SuperelevationData:
                        break;
                    case Autodesk.Civil.BandType.VerticalGeometry:
                        break;
                    default:
                        break;
                bandItem.ShowLabels = true;
Civil Reminders
Rail Community
