Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Pressure network object properties
2 REPLIES 2
Mikexlt
528 Views, 2 Replies
Is it possible to get the x,y,z coordinates for the pipe ends  and appurtenaces from .com?
2 REPLIES 2
Jeff_M
in reply to: Mikexlt
No. .NET API only. If you use vl-lisp commands you can check the COM properties and methods for any object:
; IAeccEntity: interface IAeccEntity
; Property values:
; Application (RO) = #<VLA-OBJECT IAeccApplication 000000d40dd1d360>
; Description = " "
; DisplayName (RO) = "Pressure Pipe - (1)"
; Document (RO) = #<VLA-OBJECT IAeccDocument 000000d40dd1df00>
; EntityTransparency = "ByLayer"
; Handle (RO) = "1277D"
; HasExtensionDictionary (RO) = 0
; Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 000000d40dc7c918>
; Layer = "0"
; Linetype = "ByLayer"
; LinetypeScale = 1.0
; Lineweight = -1
; Material = "ByLayer"
; Name = "Pressure Pipe - (1)"
; ObjectID (RO) = 42
; ObjectName (RO) = "AeccDbPressurePipe"
; OwnerID (RO) = 43
; PlotStyleName = "ByLayer"
; ShowToolTip = -1
; TrueColor = #<VLA-OBJECT IAcadAcCmColor 000000d40dc7d510>
; Visible = -1
; Methods supported:
; ArrayPolar (3)
; ArrayRectangular (6)
; Copy ()
; Delete ()
; GetBoundingBox (2)
; GetExtensionDictionary ()
; GetXData (3)
; Highlight (1)
; IntersectWith (2)
; IsReferenceObject ()
; IsReferenceStale ()
; IsReferenceSubObject ()
; IsReferenceValid ()
; Mirror (2)
; Mirror3D (3)
; Move (2)
; Rotate (2)
; Rotate3D (3)
; ScaleEntity (2)
; SetXData (2)
; TransformBy (1)
; Update ()
Jeff_M, also a frequent Swamper
Mikexlt
in reply to: Jeff_M
Solved my question referenced the pressurepipe AeccPressurePipesmgd
code to get to pipe values
Dim pipe As PressurePipe = tr.GetObject(per.ObjectId, OpenMode.ForRead)
Dim startx As Double = pipe.StartPoint.X
Dim starty As Double = pipe.StartPoint.Y
Dim startz As Double = pipe.StartPoint.Z
Dim endx As Double = pipe.EndPoint.X
Dim endy As Double = pipe.EndPoint.Y
Dim endz As Double = pipe.EndPoint.Z
Dim pipeId As Double = pipe.InnerDiameter.ToString
Dim pipeidInches As Double = pipeId * 12
Dim PipeLength As Double = pipe.StartPoint.DistanceTo(pipe.EndPoint)
Thanks Mike
Rail Community
