Is it possible to create user defined data fields that can be attached to a polygon.
then be able to export the polygon and data fields to ArcMap
you can use ObjectData (from the Map-functionality). There you can declare a ObjectData-Table that holds fields, you can assign for individual AutoCAD entities ObjectData-Records (holding the individual values for each geometry-item) and when you have finished your work you can use _MAPEXPORT to export the geometry + the ObjectData.
Take a look >>>to the docu here<<<
HTH, - alfred -
