So I've been working on setting up a drawing template for our variety of projects. Since it is a work in progress I have it saved as a dwg not a dwt just because it seems simpler to do a save as when I want a new drawing rather than saving over a dwt for every edit. For my latest project I had to grab some old survey data (txt format PNEZD) and import it into the drawing. The point groups that are in my "template" recognize which points belong to which group. The problem I'm having is that the default description only style will not show anything. Description & Elevation will only show elevation and so on with every style. The attached image shows the _All Points group (which is at the top of the point groups) as an example. All layers are on & thawed. I've done a regen and updated all point groups. I'm not sure why this would happen to this one part of the style.
Daniel
Solved by Dmo0430. Go to Solution.
My mistake I must have mis-clicked when I went to post. Is there a way I can move it? I'm not sure I understand. The full description is raw there is no desckey applied.
I just figured it out. One of the surveys that I imported had P,N,E,Z,,D (two commas between the elevation and description) so no description would show because it was a blank value.
