Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Point Elevation not Point Location Z
5 REPLIES 5
mikekillion
548 Views, 5 Replies
I am trying to write a routine that exports point to a CSV file. I would like the Point Elevation, but I only see the Z location property. Here is the code. Often our points are at a elevation of zero, but the elevation property is at the design grade, so the Location would not be correct. What am I missing?
        <CommandMethod("ExportPoints")> _
        Public Sub ExportPointsToCSV()
            Dim myDoc As Document = AcadNETApp.DocumentManager.MdiActiveDocument
            Dim myCivilDoc As Autodesk.Civil.ApplicationServices.CivilDocument
            myCivilDoc = CivilApplicationManager.ActiveCivilDocument
            Dim mySW As New IO.StreamWriter("C:\test.csv")
            Using myTrans As Transaction = myDoc.TransactionManager.StartTransaction
                For Each myPointID As ObjectId In myCivilDoc.GetAllPointIds
                    Dim myPoint As PointEntity = myPointID.GetObject(OpenMode.ForRead)
                    mySW.WriteLine(myPoint.PointNumber & "," & _
                                   myPoint.Location.Y.ToString & "," & _
                                   myPoint.Location.X.ToString & "," & _
                                   myPoint.Location.Z.ToString & "," & _
                                   Left(myPoint.FullDescription, 15))
                Next
            End Using
            mySW.Flush()
            mySW.Close()
            mySW.Dispose()
        End Sub
 Thank you,
Mike
5 REPLIES 5
Jeff_M
in reply to: mikekillion
The Z is the point's elevation. Where it is displayed in the drawing is controlled by the style, so the Location.Z should never change due to how it's displayed.
mikekillion
in reply to: Jeff_M
Thanks for taking a look at this Jeff.
When I select a point in the drawing and view the properties, it shown me a northing, easting and elevation. When I run this routine, the elevation of every point is 0, regardless of the elevation shown in the properties dialog. How do I retrieve the point elevation displayed in the drawing?
Mike.
Jeff_M
Oops, sorry about that! I really should learn to not post when I'm in a hurry.
The PointEntity is a newer (2011) addition to the .NET API and it appears it is not completely done. I've always used the COM API to get the elevation which IS a property of the AeccPoint object.
mikekillion
in reply to: Jeff_M
Thanks Jeff. I knew I was missing something. I will give that a try.
MIke
mikekillion
Thanks again Jeff. That was the guidance I needed.and I was able to get the code below to work.
            'This routine still relies on the COM Interface in order to get the Point elevation, not the location
            Dim myCivilDoc As AeccDocument
            myCivilDoc = CivilApplicationManager.COMActiveCivilDocument
            Dim myProjectInformation(2) As String
            myProjectInformation = myAcadApp.getProjectInformation(myDoc)
            Dim sPath As String = myProjectInformation(2) & "\08 Site Construction\Point Files\" & myProjectInformation(1) & "." & Now().ToString("yyyy-MM-dd") & ".csv"
            MsgBox(sPath)
            Dim mySW As New IO.StreamWriter(sPath)
            Dim myPoints As AeccPoints = myCivilDoc.Points
                For Each myPoint As AeccPoint In myCivilDoc.Points
                    mySW.WriteLine(myPoint.Number & "," & _
                                   myPoint.Northing & "," & _
                                   myPoint.Easting & "," & _
                                   myPoint.Elevation & "," & _
                Next
            End Using
            mySW.Flush()
            mySW.Close()
            mySW.Dispose()
        End Sub
 I did notice that the resulting file was not in point number order. Is there a way to easily retrieve the myCivilDoc.Points collection already sorted without assigning it to an array?
Thanks again. I'd been struggling with that for far longer than I hoped, and I finally worked through the COM .NET confusion I have had in migrating from VBA.
Rail Community
