Pipe Network Profile
Every time I use the command "Draw parts in Profile" I get the error menus as seen on the enclosed attachment s 01 & 02.
However after I "X" out the error menus my profile does appear.
Then when I exit the drawing I get a menu asking if I want to save my changes to the VBA project , see attachment 03.
I am not sure what this is asking so I pick NO.
If someone could tell me what I am doing wrong to keep getting these errors & what they mean, I
would be very grateful.
Thank you
Solved by Jeff_M. Go to Solution.
Hi Jeff
Thank you for your reply. I checked and I do have the latest vba "AutoCad 2013 VBA Enabler".
Also I have not been prompted to convert to .NET
It seems everything works up to the point where I pick my profile using the command "Draw parts in profile", then I get the three errors below >>>>
Also by just right picking a pipe and selecting "Pipe Properties" and toggle from one Rule Set to another I get the same three errors.
When I use C3D 2010 on this same drawing everything worksjust fine. I just do not get this.
1. Compiler error. Can't find project or library
2. Unable to run macro: C3DPipeRules.dvb!MaximumPipe Size. MaximumPipe Size_ValidateRule
3. And finally we I close the drawing I am prompt [Do you want to save changes to the VBA project,
C3DPipeRules dvd ?] & I just say No
I am not sure what the VBA does , or if I really need it. Should I uninstall it ?
The problem is that the VBA code has not been updated for use with 2013. The VBA enabler has been known to slow down 64 bit systems so I have never even installed it. Unless you have your own custom pipe/structure rules or subassemblies for corridors, I would suggest uninstalling the VBA enabler. Try running the command CONVERTVBARULESTODOTNET to convert the drawing to .NET. I think that will solve this problem for you.
