Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Pipe Network Catalog Settings
2 REPLIES 2
421 Views, 2 Replies
Hi
I'm trying to set the pipe networks catalog, the folder path is correct,  but the pipe and structures catalog doesn't appear.
Tkanks
C Deoliveira
2 REPLIES 2
Civil3DReminders_com
Hopefully you figured out the problem. If not make sure you pick the folder above the folders that contain the pipes and structures.
So this is the default location in Civil 3D
C:\ProgramData\Autodesk\C3D 2016\enu\Pipes Catalog\
and then the structures and pipes have their own folders below that.
C:\ProgramData\Autodesk\C3D 2016\enu\Pipes Catalog\Metric Structures
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
pthies
Try running the command PARTCATALOGREGEN, and selecting both "Pipe" and "Structure" and see if it recognizes your catalog then.
Rail Community
