Hi
I'm trying to set the pipe networks catalog, the folder path is correct, but the pipe and structures catalog doesn't appear.
Tkanks
C Deoliveira
Hopefully you figured out the problem. If not make sure you pick the folder above the folders that contain the pipes and structures.
So this is the default location in Civil 3D
C:\ProgramData\Autodesk\C3D 2016\enu\Pipes Catalog\
and then the structures and pipes have their own folders below that.
C:\ProgramData\Autodesk\C3D 2016\enu\Pipes Catalog\Metric Structures
Try running the command PARTCATALOGREGEN, and selecting both "Pipe" and "Structure" and see if it recognizes your catalog then.
