Hi, can I get into point code label in section name of parent alignment? If I use <[Parent Alignment(CP)]>, the result label is ???. And how to get into same label cant and curve radius value. Thank you
A few things..First, welcome to the Civil 3d forums! Second, there are a few C3D related forums, this one is dedicated for discussion related to programming customization issues & solutions. For general C3D questions, such as yours, you should place those in the main C3D forum . Third, could you create an image of what you are trying to accomplish. I'm guessing this is all in a sectionview of a Corridor Section?
hi, excuse me that I place this topic into bad discussion.
What I need. You can see it on attached pic. I need to add label, with cant and radius value into section view. Thank you
The way I would solve this issue would be to create a profile with the elevation set as the radius of the curve and/or D value. I'd then have a link slope Width that will target the profile. In the section view it would use the length of the link to show the curve and/or D value. Not dynamic, but would be easier then typing the value each time.
