Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Parcel Areas
7 REPLIES 7
Message 1 of 8
381 Views, 7 Replies
Parcel Areas
I'm new into VBA programming. I did a tool that calculates the total area
by parcel styles within a specific site. Basically what I did is created a
loop and an IF statement to filter out parcels by styles, and after that put
the total parcel areas by style in an array for later use. Everyting seems
to work fine, but it takes forever to calculate the toal areas when I run
it, since it loops trhough out approx. 600 parcels. Should I be doing this
differently? Any ideas would be appreciated. Thanks
7 REPLIES 7
Message 2 of 8
Hi Francisco,
600 parcels should be trivial.
It is more likely that you looping structures are inefficient.
Can post post your program and drawing (delete everything but the 600
parcels from the drawing then purge, to reduce overhead ) If the drawing is
still over about 200Kb, post it to the customer files rather than here.
Regards
Laurie Comerford
"Francisco J. Bobadilla" wrote in message
news:5860237@discussion.autodesk.com...
Message 3 of 8
Laurie,
I have posted the file to the customer files group. Here is the code I'm
using for my looping. Thanks for your help.
Option Explicit
Public txtbox As MSForms.TextBox
Public Sub CommandButton1_Click()
Me.OK.Enabled = True
Dim pstyle As String
Dim k As Integer
Dim n As Integer
Dim cvalue As String
Dim txtbox As MSForms.TextBox
Dim ctlLabel As MSForms.Control
n = g_oDocument.ParcelStyles.Count
For k = 0 To n - 1
pstyle = g_oDocument.ParcelStyles.Item(k).Name
Set ctlLabel = Me.Controls.Add("forms.Label.1")
With ctlLabel
.Name = pstyle & k
.Width = Me.Width
.TextAlign = fmTextAlignCenter
.top = 20 + (12 * k)
.Caption = pstyle
.Left = -15
.Height = 15
.Move -45
End With
Set txtbox = Me.Controls.Add(("Forms.textbox.1"), "txtbox" & k, Visible)
With txtbox
.Width = 60
.Left = 15
.Height = 15
.Move 115
txtbox.Text = "test" & k
End With
Next
End Sub
Private Sub OK_Click()
Dim k As Integer
Me.CommandButton1.Enabled = True
Dim txtbox As TextBox
Dim txt As TextBox
Dim CW As Double
Dim ck As Double
Dim totalarea As Double
Dim parea As AeccParcelStatistics
Dim area As Double
Dim z As Integer
area = 0
Dim j As Integer
j = g_oDocument.Sites.Item(0).Parcels.Count
For k = 0 To n - 1
Set txtbox = Me.Controls.Item("txtbox" & k)
cvalue = txtbox.Text
ReDim areasArray(n, 3)
areasArray(k, 1) = g_oDocument.ParcelStyles.Item(k).Name
For z = 0 To j - 1
If areasArray(k, 1) =
g_oDocument.Sites.Item(0).Parcels.Item(z).StyleName Then
area =
g_oDocument.Sites.Item(0).Parcels.Item(z).Statistics.area + area
Else
End If
Next
areasArray(k, 2) = area
areasArray(k, 3) = areasArray(k, 2) * CDbl(cvalue)
totalarea = totalarea + areasArray(k, 2)
ck = ck + areasArray(k, 3)
Next
CW = ck / totalarea
End Sub
Private Sub UserForm_Click()
End Sub
"Laurie Comerford" wrote in message
news:5860716@discussion.autodesk.com...
Hi Francisco,
Regards
Laurie Comerford
Message 4 of 8
Hi Francisco,
I didn't find your drawing, but can make a couple
of comments about the code:
' Loop through parcels
styles:
For k = 0 To n - 1
    Set txtbox =
    cvalue =
txtbox.Text
color=#ff0000> ' Note you are redimming this inside the
loop
'    and hence lose the data from the previous run
through the loop
    areasArray(k, 1) =
    For z = 0 To j - 1 '
Loop through the parcels'
        If
areasArray(k, 1) = g_oDocument.Sites.Item(0).Parcels.Item(z).styleName
Then
            area
= g_oDocument.Sites.Item(0).Parcels.Item(z).Statistics.area +
area
    End If
Next
    ck = ck +
areasArray(k, 3)
Next
What you have done here is to use the
item with the smaller number of entries as the outer loop and then processed
every item in the inner loop for each of the items in the outer
loop.
Thus in total you will run through
the loop "NoOfParcels * NoOfStyles" times.
If you cycle through the parcels in
the outer loop and find the style for the parcel - on average you will find the
parcel style half way through the style count and hence you will go through the
loop about half the number of times - and with an overhead of checking to exit
the loop.
I've written some code to put the
data in a list box.  This does not requre the array to hold the data and is
certainly slower than using an array as I have to convert the data backwards and
forwards between values and strings.  I should have used a 'double array'
to hold the data till ready to write it to the form
For this you need a form with a
combobox from which to select the required site, a list box to display the data
and two command controls.  One to run the program and to exit the
form.
<Code start for
Module>
Option Explicit
Public g_oCivilApp As AeccApplication
Public
g_oAeccDoc As AeccDocument
size=2>
Start Civil 3D and create Civil 3D document
object.
Function
getCivilObjects() As Boolean
Dim sAppName As String
Dim oApp As
AcadApplication
    Set oApp =
ThisDrawing.Application
    sAppName =
"AeccXUiLand.AeccApplication.5.0"
    Set g_oCivilApp =
oApp.GetInterfaceObject(sAppName)
    If g_oCivilApp Is
Nothing Then
        MsgBox "Error
creating " & sAppName & ",
exit."
        getCivilObjects =
False
        Exit
Function
    End If
    Set g_oAeccDoc =
g_oCivilApp.ActiveDocument
    getCivilObjects = True
End
Function
Sub Start()
Dim bParcelsFound As
Boolean
  getCivilObjects
  For Each oSite In
g_oAeccDoc.Sites
    If oSite.Parcels.Count > 0
Then
      bParcelsFound =
True
      Exit For
    End
If
  Next
  If bParcelsFound = False Then
MsgBox "No parcels found in drawing"
  Else
UserForm1.Show
  End If
End Sub
<End module
code>
<Start form code>
face=Arial color=#ff0000 size=2>
Private Sub
UserForm_Initialize()
Dim iStyleNum As Integer
Dim iParcelNum As
Integer
Dim bParcelsFound As Boolean
Dim oSite As AeccSite
  Me.Width = 400
  Me.ListBox1.Width =
220
  Me.ListBox1.ColumnCount = 3
  Me.ListBox1.ColumnWidths =
60
  Me.ListBox1.TextAlign = fmTextAlignRight
Me.ListBox1.ColumnHeads = False
  Me.ListBox1.Clear
Me.ListBox1.AddItem "NAME "
  Me.ListBox1.List(0, 1) = "STYLE"
Me.ListBox1.List(0, 2) = "AREA"
  For iStyleNum = 0 To
g_oAeccDoc.ParcelStyles.Count - 1
    Me.ListBox1.AddItem
"Test " & CStr(iStyleNum)
    Me.ListBox1.List(iStyleNum +
1, 1) = g_oAeccDoc.ParcelStyles.Item(iStyleNum).Name
Me.ListBox1.List(iStyleNum + 1, 2) = ""
  Next iStyleNum
Me.ListBox1.AddItem "Total"
  cbSites.Clear
  For Each oSite In
g_oAeccDoc.Sites
Then
      cbSites.AddItem
oSite.Name
    End If
  Next
cbSites.ListIndex = 0
End Sub
Dim i As Integer
Dim iParcelNum As
Integer
Dim iNumParcels As Integer
Dim iNumParcelStyles As Integer
Dim
oSite As AeccSite
Dim oParcel As AeccParcel
Dim dArea() As Double
Dim
dTotal As Double
' Select the site to process from the
sites list box
  Set oSite =
g_oAeccDoc.Sites.Item(cbSites.ListIndex)
  iNumParcels =
oSite.Parcels.Count
  iNumParcelStyles =
  ReDim dArea(1 To
iNumParcelStyles)
' Loop through the parcels -- each
parcel only addressed once
  For iParcelNum = 0 To iNumParcels -
1
    Set oParcel = oSite.Parcels.Item(iParcelNum)
color=#008000> ' find the listindex in the listbox which matches the parcel
style
 ' The styles are addressed several times, but only till the style
for each parcel is found
    i =
1
    Do While Not oParcel.Style.Name = Me.ListBox1.List(i,
1)
      i = i + 1
Loop
 ' Add the cummulative area for that style to
the list box
    dArea(i) = dArea(i) +
oParcel.Statistics.area
  Next iParcelNum
Format the areas and add to the form
  For i = 1 To
Me.ListBox1.ListCount - 2
    If dArea(i) > 0
Then
      Me.ListBox1.List(i, 2) = Format(dArea(i),
"#0.000")
      dTotal = dTotal +
dArea(i)
    Else
Me.ListBox1.List(i, 2) = ""
    End If
Me.ListBox1.List(Me.ListBox1.ListCount - 1, 2) =
Val(Me.ListBox1.List(Me.ListBox1.ListCount - 1, 2)) + Val(Me.ListBox1.List(i,
2))
  Next i
Format(dTotal, "#0.000")
End Sub
Private Sub cmdExit_Click()
  me.Hide
End
Sub
<End form code>
I made a drawing with 880 parcels with two of five
label styles used ( I had 11 and simply made a 20 * 4 array of them.)
My code took about 25 seconds for this data set
doing 1780 passes (most of the parcels were labelled with the second style)
through the loop whereas your code would have done 4400.
The screen grab shows the form I used.
Regards
Laurie Comerford
size=2>Laurie,
<snip>
Message 5 of 8
Hi Francisco,
Your drawing is now available.
I noticed that you have put your code in the drawing. This is NOT a good
idea particularly if you want other users to open the drawing.
However I opened the drawing without enabling its macros and wblocked it to
a clean drawing.
My program ran in about 15 seconds on the wblocked drawing.
Regards
Laurie Comerford
"Francisco Bobadilla" wrote in message
news:5863610@discussion.autodesk.com...
Laurie,
Option Explicit
Dim k As Integer
Dim n As Integer
For k = 0 To n - 1
With ctlLabel
.Name = pstyle & k
.Width = Me.Width
.Caption = pstyle
.Left = -15
.Height = 15
.Move -45
End With
With txtbox
.Width = 60
.Left = 15
.Height = 15
.Move 115
End With
Next
End Sub
Dim k As Integer
Dim txt As TextBox
Dim CW As Double
Dim ck As Double
Dim area As Double
Dim z As Integer
area = 0
Dim j As Integer
For k = 0 To n - 1
For z = 0 To j - 1
area =
Else
End If
Next
Next
CW = ck / totalarea
End Sub
End Sub
Hi Francisco,
Regards
Laurie Comerford
Message 6 of 8
Thanks for your comments Laurie. I did figure out a way to loop parcels
more efficiently. THis only takes probably 1-2 seconds at the most. I use
the For Each Parcel in aparcels function. Which aparcels is the total
collection of parcels and parcel is just a variable defined as parcel.
Seems to work pretty good even though took me the entire weekend to figure
it out. I didn't get your last comment about creating the code in the
drawing. Could you please explain this to me?. I'm new in VB and trying to
learn. The way I created this code was using the vbaide (VBA editor inside
autocad), and created a new project there. Thanks for your help I
appreciate it.
news:5863710@discussion.autodesk.com...
Hi Francisco,
a clean drawing.
Regards
Laurie Comerford
Laurie,
Option Explicit
Dim k As Integer
Dim n As Integer
For k = 0 To n - 1
With ctlLabel
.Name = pstyle & k
.Width = Me.Width
.Caption = pstyle
.Left = -15
.Height = 15
.Move -45
End With
With txtbox
.Width = 60
.Left = 15
.Height = 15
.Move 115
End With
Next
End Sub
Dim k As Integer
Dim txt As TextBox
Dim CW As Double
Dim ck As Double
Dim area As Double
Dim z As Integer
area = 0
Dim j As Integer
For k = 0 To n - 1
For z = 0 To j - 1
area =
Else
End If
Next
Next
CW = ck / totalarea
End Sub
End Sub
Hi Francisco,
Regards
Laurie Comerford
Message 7 of 8
he meant to put the code in a dvb, not the drawing.
If you make a new project in the VBAMAN dialog, you can save it as a dvb once in the VBAIDE.
thx
Francisco Bobadilla
|>appreciate it.
|>Hi Francisco,
|>a clean drawing.
|>Regards
|>Laurie Comerford
|>Laurie,
|>Option Explicit
|> Dim k As Integer
|> Dim n As Integer
|> For k = 0 To n - 1
|> With ctlLabel
|> .Name = pstyle & k
|> .Width = Me.Width
|> .Caption = pstyle
|> .Left = -15
|> .Height = 15
|> .Move -45
|> End With
|> With txtbox
|> .Width = 60
|> .Left = 15
|> .Height = 15
|> .Move 115
|> End With
|> Next
|> End Sub
|>Dim k As Integer
|>Dim txt As TextBox
|>Dim CW As Double
|>Dim ck As Double
|>Dim area As Double
|>Dim z As Integer
|>area = 0
|>Dim j As Integer
|>For k = 0 To n - 1
|> For z = 0 To j - 1
|> area =
|> Else
|> End If
|> Next
|>Next
|>CW = ck / totalarea
|>End Sub
|>End Sub
|>Hi Francisco,
James Maeding
Civil Engineer and Programmer
jmaeding - at - hunsaker - dotcom
Message 8 of 8
Thaks James. I thought that's what I did. I created a dvb, possibly left
the code in the drawing as well. Thanks
"James Maeding" wrote in message
news:5864481@discussion.autodesk.com...
once in the VBAIDE.
thx
Francisco Bobadilla
use
to
inside
|>appreciate it.
|>Hi Francisco,
to
|>a clean drawing.
|>Regards
|>Laurie Comerford
|>Laurie,
|>Option Explicit
|> Dim k As Integer
|> Dim n As Integer
|> For k = 0 To n - 1
|> With ctlLabel
|> .Name = pstyle & k
|> .Width = Me.Width
|> .Caption = pstyle
|> .Left = -15
|> .Height = 15
|> .Move -45
|> End With
Visible)
|> With txtbox
|> .Width = 60
|> .Left = 15
|> .Height = 15
|> .Move 115
|> End With
|> Next
|> End Sub
|>Dim k As Integer
|>Dim txt As TextBox
|>Dim CW As Double
|>Dim ck As Double
|>Dim area As Double
|>Dim z As Integer
|>area = 0
|>Dim j As Integer
|>For k = 0 To n - 1
|> For z = 0 To j - 1
|> area =
|> Else
|> End If
|> Next
|>Next
|>CW = ck / totalarea
|>End Sub
|>End Sub
|>Hi Francisco,
is
James Maeding
Rail Community
