Does anyone how a person might go about making it so that ALL Feature Objects are created on a NOPLOT layer when created Using a wildcard alias in the Drawing Settings > Object Layers? Any ideas are apprciated
Solved by Jeff_M. Go to Solution.
The only thing I can think of is to create a Layer Filter for your FEATURE-LAYER-* so that you can quickly check and change them after they are created.
