Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
.NET v4.0 COM Interop. Can't get Database via late bind? C3D 2012 SP1
2 REPLIES 2
rutar
533 Views, 2 Replies
Hello!
After resolving trouble with versions changing 107->49, AecXBase, AecXUIBase are now visible,
I have another one -  m_oAeccDoc.GetType().GetProperty("Database") is null,
in .NET version 3.5 - all works fine,
it happens after changing to .NET version 4.0 and references  to newer ones.
________________________________________________________________________________________
m_oAcadApp = (IAcadApplication)System.Runtime.InteropServices.Marshal.GetActiveObject(m_sAcadProdID);
if (m_oAcadApp != null)
m_oAeccApp = (IAeccApplication)m_oAcadApp.GetInterfaceObject(m_sAeccAppProgId);
m_oAeccDoc = (IAeccDocument)m_oAeccApp.ActiveDocument;
// get the Database object via a late bind - here m_oAeccDoc.GetType().GetProperty("Database") is null
m_oAeccDb = (Autodesk.AECC.Interop.Land.IAeccDatabase)m_oAeccDoc.GetType().GetProperty("Database").GetValue(m_oAeccDoc, null);
_________________________________________________________________________________________
Is any possibility to change "Using Interop" Autodesk API Developers guide from .NET 3.5 2010, to v4.0 2012 and also Samples directory files  or  write somwhere  how to use  COM Interop in C3D2012 SP1?
2 REPLIES 2
tomg
in reply to: rutar
Take a look at the Answer Solution C# DotNetComInterop Sample.
Tom
rutar
in reply to: tomg
Thanks, tomg.
I'd applyed that registry modification (107->49 version) before, to have AecXBase, AecXUIBase visible.
Now changed in  C# ProjectOptions target .NET framework version to 3.5 - all works,
and it possible to load that dll via netload  and run
in C3D 2012 (autocad.config - using .NET version 4.0) all works fine.
Is it normal application behaivior?
Rail Community
