Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
need help with making a lisp
5 REPLIES 5
htls69
466 Views, 5 Replies
so i was wondering if one you smart guys here could help me out
i need a lsp routine that i can associate with a toolbar button that will reset the "table tag renumbering" "line stating number & curve starting number" the the number 1 with out me having to open 2 different dialog boxes.
if this is easy and can be done i would really appreciate it
(see Picture for what i want to change)
autodesk civil 3d 2012 all updates applied
win7 x64
Allen Robberson
Credit where credit is due! Give kudos or accept as solution whenever you can.
5 REPLIES 5
Jeff_M
in reply to: htls69
The properties to get/set these values are not available in the COM/ActiveX API. They are, however, available in the .NET API for 2013+.
So, no to the lisp, no for something in 2012, yes it could be done with a .NET application for 2013+
htls69
in reply to: Jeff_M
WE ARE MOVING TO CIVIL 3D 2015 IN 3 MONTHS
would be nice if you could create that for me please
Allen Robberson
Jeff_M
in reply to: htls69
Attached is a zip file with a .NET dll. After downloading, find the zip file with Windows Explorer, right click on it, select Properties. On the General tab, be sure there is no button labeled "Unblock", if there is one, click it, then exit the properties. Now extract the dll to a location you will remember, and, in 2014/2015, is a Trusted path. Load it into C3D2013, 2014, or 2015 with the NETLOAD command, this can be added to your acad.lsp file to auto load it everytime C3D is started. Once loaded, the command is "ResetRenumberingTo1".
For those curious about the actual code, this is it, in it's entirety:
using Autodesk.AutoCAD.Runtime;
using Autodesk.Civil.ApplicationServices;
using Autodesk.Civil.Settings;
namespace ResetRenumbersToOne
    public class ResetRenumbersToOne
        [CommandMethod("ResetRenumberingTo1")]
        public void resetrenumbersto1()
            CivilDocument civdoc = CivilApplication.ActiveDocument;
            SettingsTag settings = civdoc.Settings.TagSettings;
            settings.Renumbering.CurvesStartingNumber = 1;
            settings.Renumbering.LinesStartingNumber = 1;
htls69
in reply to: Jeff_M
i dont see the zip file
can you email it to be at allenrobberson at gmail dot com
Allen Robberson
Jeff_M
in reply to: Jeff_M
here's the file, sorry about that.
Rail Community
