Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Managing existing SHP connection
0 REPLIES 0
Message 1 of 1
zdenek.neustupa.st1
293 Views, 0 Replies
Hello.
I am quite new to FDO so my question may sound little bit silly.
I just would like to know, if it is possible to manage a connection to SHP files, which is already created.
The situation: I have dwg file to which are connected several SHP files containing data. I can see and configure this connection in AutoCAD Civil 3D 2012 using Data Connections dialog window.
I learned how to make a new connection using
OSGeo.FDO.ClientServices.FeatureAccessManager.GetConnectionManager().CreateConnection(“OSGeo.SHP”).
But if I use a select command to filter some data from the SHP files it doesn’t influence the tables which are displayed in AutoCAD Map 2012.
Is there any way to access the created connection and then to execute a command using that connection?
Either via FDO or MapGuide dlls?
Thank you very much.
Zdeněk Neustupa
Tags (3)
0 REPLIES 0
Rail Community
