Do you have a .bak backup file? Or are you using Vault, where you can grab a
previous version?
John
"edge691" wrote in message news:5906283@discussion.autodesk.com...
Hello all,
I'm hoping someone out there has a solution. I am running Civil 3D 2008. I
have a large file, 30mb, with 30 paper space tabs. The file was completely
setup viewport wise; all the layers had been frozen on/off to show
appropriate data on each tab. I go back in today and all my viewports have
lost the settings. The file has about 1500 layers, and to recreate the
setups would take 30Plus hours at least. I need a lisp, or an example of
something similar, that will copy all the settings from one file into
another. Any help would be greatly appreciated.
Also before it is suggested, I cannot import the tabs & settings using the
create tab from template as every time I do the program crashes with a fatal
error. I've also tried to bring in the tabs using design center but the
settings do not come with the tabs this way.
Mike S.
