what type of development are you working with? LISP, VBA, VB.NET, ARX, ....?
That is important to be able to give you any tips.
For dotNET I usually use
<DllImport("user32.dll")> _ Private Shared Function SetFocus(ByVal hwnd As System.IntPtr) As System.IntPtr End Function 'and the call to that function Call SetFocus(Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Window.Handle)
- alfred -
Alfred
Sort ouf along the same lines but in reverse
I am trying to create catchments using the sendcommand and sendkeys as catchment objects are not exposed in the API yet. However on launching the command the Create Catchment Object dialog grabs the focus away from my code. Do you know anyway to return the focus to your code. I was thinking another dll with a windows hook listening for the dialog to appear but maybe you know a better way.
