Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
loosing focus
3 REPLIES 3
ebo134
310 Views, 3 Replies
loosing focus
Hi, every one
I designed a window with a pick button, when I hit the button for selecting an alignment ,iam loosing the focus on autocad civil 3d 2013,what should I do to fix that
thanks
Tags (1)
3 REPLIES 3
Alfred.NESWADBA
in reply to: ebo134
what type of development are you working with? LISP, VBA, VB.NET, ARX, ....?
That is important to be able to give you any tips.
For dotNET I usually use
<DllImport("user32.dll")> _
Private Shared Function SetFocus(ByVal hwnd As System.IntPtr) As System.IntPtr
End Function
'and the call to that function
Call SetFocus(Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Window.Handle)
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
ralstogj
in reply to: Alfred.NESWADBA
Alfred
Sort ouf along the same lines but in reverse
I am trying to create catchments using the sendcommand and sendkeys as catchment objects are not exposed in the API yet. However on launching the command the Create Catchment Object dialog grabs the focus away from my code. Do you know anyway to return the focus to your code. I was thinking another dll with a windows hook listening for the dialog to appear but maybe you know a better way.
Regards
Justin Ralston
http://c3dxtreme.blogspot.com/
ebo134
in reply to: ralstogj
Thank you alfred, but it didnt work for me, can you have any other solution
thanks
Rail Community
