Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
live pop up for measuregeom
3 REPLIES 3
allanbsteven
294 Views, 3 Replies
Hi There,
As surveyors we like to check point to point information such as
Distance = 14.818,  Angle in XY Plane = 66d47'14",  Angle from XY Plane = 90d0'0"
Delta X = 13.618,  Delta Y = 5.840,   Delta Z = 0.000
Which you can do in the masuregeom command. Say I had a station and wanted to do multiple observations, would it be possible to have a running "Live" pop up window to show this information as i run checks from surveyed marks to the station?
Way beyond my head, but it would be nice to have an option.
Cheers
Allan
3 REPLIES 3
Jeff_M
in reply to: allanbsteven
The POINV command in Sincpac-C3D has a Multiple option so you can get the information from 1 point to many others.
htls69
try this lisp routine maybe it could be modified to have a pop up of the info
(vl-load-com)
(defun c:si (/) (c:single-inv) )
(defun c:single-inv ( / invReport dist ang p1 p2 pt1x pt1y pt1num pt1desc pt2x pt2y pt2num pt2desc pt1 pt2 selectedPts1 selectedPts2 cmdecho osmode dxftype dashline notset GetDesc RealOut errInit errTrap errReset errRestoreVars tempErr )
	(defun errInit( / )
		(setq
			cmdecho (getvar 'cmdecho)
			osmode (getvar 'osmode)
			tempErr *error*
			*error* errTrap
		(princ)
	(defun errTrap( msg / )
		(command nil nil nil)
		(if (not (member msg '("console break" "Function Cancelled") ) )
			(princ (strcat "\nError: " msg) )
		(errRestoreVars)
		(princ "\nResetting Environment ")
		(terpri)
		(setq *error* tempErr)
		(princ)
	(defun errRestoreVars( / )
		(if osmode (setvar 'osmode osmode) )
		(if cmdecho (setvar 'cmdecho cmdecho) )
		(princ)
	(defun errReset( / )
		(errRestoreVars)
		(princ)
	(defun GetDesc( obj / ) (vlax-get-property obj 'Description) )
	(defun RealOut( d / ) (rtos d 2 4) )
	(errInit)
	(setq
		dxftype "AECC_COGO_POINT"
		notset "*PROPERTY NOT SET*"
	(setvar 'cmdecho 1)
	(if (and (setq selectedPts1 (entsel (strcat "\nSelect first point: ") ) ) (eq (cdr (assoc 0 (entget (car selectedPts1) ) ) ) dxftype) )
		(progn
			(setq
				pt1 (vlax-ename->vla-object (car selectedPts1) )
				pt1x (vlax-get-property pt1 'Easting)
				pt1y (vlax-get-property pt1 'Northing)
				pt1num (vlax-get-property pt1 'Number)
				pt1desc (vl-catch-all-apply 'GetDesc (list pt1) )
			(if (vl-catch-all-error-p pt1desc) (setq pt1desc notset) )
			(setq selectedPts2 (entsel (strcat "\nSelect second point: ") ) )
			(if (eq (cdr (assoc 0 (entget (car selectedPts2) ) ) ) dxftype)
			  (progn
					(setq
						pt2 (vlax-ename->vla-object (car selectedPts2) )
						pt2x (vlax-get pt2 'Easting)
						pt2y (vlax-get pt2 'Northing)
						pt2num (vlax-get pt2 'Number)
						pt2desc (vl-catch-all-apply 'GetDesc (list pt2) )
					(if (vl-catch-all-error-p pt2desc) (setq pt2desc notset) )
					(setq
						p1 (list pt1x pt1y 0.0)
						p2 (list pt2x pt2y 0.0)
						dist (distance p1 p2)
						ang (angtos (angle p1 p2) 4 6)
						dashline "\n-------------------------------------------------------------------"
					(setq invReport (strcat "\n\n>>From point number: " (itoa pt1num) ": " pt1desc "\n>>To point number: " (itoa pt2num) ": " pt2desc "\n" dashline "\n                       INVERSE LINE DATA" dashline "\nBegin . . . . .  X: " (RealOut pt1x) "'         Y: " (RealOut pt1y) "'\nEnd . . . . . .  X: " (RealOut pt2x) "'         Y: " (RealOut pt2y) "'\n          Distance: " (RealOut dist) "'         Course: " ang) )
				(princ "\n...not a point object, try again.")
		(princ "\nWrong object/nothing selected")
	(princ invReport)
	(errReset)
	(princ)
(princ)
Allen Robberson
Credit where credit is due! Give kudos or accept as solution whenever you can.
allanbsteven
in reply to: htls69
I was thinking it would show all this information running, so I can quickly click on multiple points frm a station and see the information literally giving me a live feed.
e.g. Click on station, a temporary line is then cretaed to start from that station, then click on points from that station and have the infomation live....great for quick checks...
A program called 12d does something similar, very handy.
Cheers
Al
Rail Community
