Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
lisp to plot layout tabs to a custom directory
1 REPLY 1
461 Views, 1 Reply
I have created this lisp to plot layouts to a plt file.  It works perfectly.  I modified the lisp to plot to a pdf and i get this error:
Lisp file:
(defun c:plot-pdf (/ layoutname layt_lst)
(vl-load-com)
(vlax-for layt (vla-get-layouts (vla-get-ActiveDocument (vlax-get-acad-object)))
(if (> (vla-get-TabOrder layt) 0)
(setq layt_lst (cons (cons (vla-get-TabOrder layt) (vla-get-Name layt)) layt_lst))
(setq layt_lst (vl-sort layt_lst '(lambda (x y) (< (car x) (car y)))))
(foreach layt layt_lst
(setq layoutname (cdr layt))
(setq dname (getvar "dwgname"))
(setq projname (substr dname 1 4))
(setq date (rtos (getvar "cdate") 2 6))
(setq year (substr date 1 4))
(setq month (substr date 5 2))
(setq day (substr date 7 2))
(setq location1 (strcat "Q:\\RCMA RESOURCES\\Plots Temp\\" projname " (" year "-" month "-" day ")"))
(vl-mkdir location1)
(setq location2 (strcat location1 "\\" projname "Plotfile"))
(vl-mkdir location2)
(setq location3 (strcat location1 "\\" projname "PDF"))
(vl-mkdir location3)
(setq plotdir location2)
(setq pdfdir location3)
(setq plotname layoutname)
(setq location (strcat plotdir "\\" plotname))
(setq location-b (strcat pdfdir "\\" plotname))
(command "-plot"
"yes";DETAILED PLOT
layoutname
"DWG To PDF.pc3";PLOTTER NAME
"ARCH D (24.00 x 36.00 Inches)";PAPER SIZE
"inches";PAPER UNITS
"landscape";ORIENTATION
"no";PLOT UPSIDEDOWN
"extents";PLOT AREA
"1:1";PLOT SCALE
"center";PLOT OFFSET
"yes";USE PLOT SYTLES
"RCMA-FULL.CTB";PLOT STYLE NAME
"yes";PLOT LINEWEIGHTS
"no";SCALE LINEWEIGHTS
"no";PAPER SPACE FIRST
"No";HIDE PAPER SPACE
"Yes";PLOT TO FILE
location-b
"yes";SAVE PAGE SETUP
"yes";PROCEDE WITH PLOT
(princ)
Error I am getting:
-plot Detailed plot configuration? [Yes/No] <No>: yes
Enter a layout name or [?] ❤️ SITE DETAILS>: 3 SITE DETAILS Enter an output device name or [?] <DWG To PDF.pc3>: DWG To PDF.pc3 Enter paper size or [?] <ARCH D (24.00 x 36.00 Inches)>: ARCH D (24.00 x 36.00 Inches) Enter paper units [Inches/Millimeters] <Inches>: inches Enter drawing orientation [Portrait/Landscape] <Landscape>: landscape Plot upside down? [Yes/No] <No>: no Enter plot area [Display/Extents/Limits/View/Window] <Extents>: extents Enter plot scale (Plotted Inches=Drawing Units) or [Fit] <1:1>: 1:1 Enter plot offset (x,y) or [Center] <Center>: center Plot with plot styles? [Yes/No] <Yes>: yes Enter plot style table name or [?] (enter . for none) <RCMA-FULL.CTB>: RCMA-FULL.CTB Plot with lineweights? [Yes/No] <Yes>: yes Scale lineweights with plot scale? [Yes/No] <No>: no Plot paper space first? [Yes/No] <No>: no Hide paperspace objects? [Yes/No] <No>: No
Enter file name <Q:\RCMA RESOURCES\1 CAD Management\C3D STYLES\Test Project\6 CAD Files\4 Plan Sheets\TEST 03 DET1-3 SITE DETAILS.pdf>: Yes Save changes to page setup [Yes/No]? <N> Q:\RCMA RESOURCES\Plots Temp\TEST (2016-10-07)\TESTPDF\3 SITE DETAILS
Yes or No, please.
error: Function cancelledSave changes to page setup [Yes/No]? <N> *Cancel*
Does anyone have any ideas?
1 REPLY 1
Jeff_M
When using the DWG To PDF.pc3 there is no prompt for Plot To File because by definition you will be doing just that. SO when it is asking for the name of the file, you respond with Yes. Omit that line and it should be good to go.
Rail Community
