I'm looking for a LISP that could extract the point description from a cogo point as a piece of MTEXT ot DTEXT.
A bonus would be to select a group of points, have each description extracted as MTEXT individually and placed very near the point marker.
Has anyone seen one that can do this?
Thanks!
Solved by Jeff_M. Go to Solution.
I can cobble together and tweak some easy stuff but creating this from scratch is beyond me.
I found a good piece. I think my code would at least include something like this:
(defun c:desc ()
(foreach pnt selectedPnts
(setq descr (vlax-get (vlax-invoke pnts 'findpnt) 'fulldescription)
eastng (vlax-get (vlax-invoke pnts 'find pnt) 'easting)
northng (vlax-get (vlax-invoke pnts 'findpnt) 'northing)
(command "text" "c" eastng,northng "E" descr)
(princ)
but how do I select the points?
-Joe
Since you are getting more than one proerty from the cogopoint, save it to a variable instead of having multiple calls to the 'Find method. Here's an updated version for you to ponder:
(defun c:desc (/ c3d c3ddoc descr eastng northng pntobj pnts selectedpnts) (vl-load-com) (setq C3D (strcat "HKEY_LOCAL_MACHINE\\" (if vlax-user-product-key (vlax-user-product-key) (vlax-product-key) ) ) C3D (vl-registry-read C3D "Release") C3D (substr C3D 1 (vl-string-search "." C3D (+ (vl-string-search "." C3D) 1)) ) C3D (vla-getinterfaceobject (vlax-get-acad-object) (strcat "AeccXUiLand.AeccApplication." C3D) ) ) (setq c3ddoc (vlax-get c3d 'activedocument) pnts (vlax-get c3ddoc 'points) selectedPnts (vlax-invoke c3ddoc 'selectpoints) ) (foreach pnt selectedPnts (setq pntobj (vlax-invoke pnts 'find pnt)) (setq descr (vlax-get pntobj 'fulldescription) eastng (vlax-get pntobj 'easting) northng (vlax-get pntobj 'northing) ) (command "text" "c" (list eastng northng) "E" descr) ;;this will fail if the current style has a 0 text height ) (vlax-release-object c3d) (princ) )
ANother method that doesn't require the AeccApplication:
(defun c:desc2 (/ descr eastng idx northng pnt pntobj ss) (if (setq ss (ssget '((0 . "AECC_COGO_POINT")))) (progn (setq idx -1) (while (setq pnt (ssname ss (setq idx (1+ idx)))) (setq pntobj (vlax-ename->vla-object pnt)) (setq descr (vlax-get pntobj 'fulldescription) eastng (vlax-get pntobj 'easting) northng (vlax-get pntobj 'northing) ) (command "text" "c" (list eastng northng) "E" descr) ;;this will fail if the current style has a 0 text height ) ) ) (princ) )
Jeff,
I'm looking for a method in LISP to select Cogo Points by Point Number, as you would on the command line such as 'PN.
I'm planning to write a LISP program that can prepare Radial Stake Out reports, since Autodesk Civil 3D Reports fails to produce such reports because it uses HTML langauge and it will not work on IE9+.
The program itself should be relatively simple just as it was for LDD. The math and logic for LISP should be very easy. The only difficulties I may have is selecting the Cogo points by number and parcing out Foresight Point entries such as 100,113-125. My first thought would be to have the FS points in a Point Group before running the program, thus having the user select the Point Group to grab all of the points within the group.
(setq BS-Az (angle OC-PT BS-Pt)
BS-Dist (itoa (distance OC-PT BS-PT))
FS-Az (angle OC-PT BS-Pt)
FS-Dist (itoa (distance OC-PT FS-PT))
AngleRT (angtos (- FS-Az BS-Az) 4 6)
);set
Command: Enter Occupied Point: 1
Command: Enter Backsight Point: 2
Command: Enter Foresight (Stakeout) Points: 100,113-125
Result
-------------------------------- Radial Stake Out Report ---------------------------------
Pt# Northings Eastings Elevation Description
Occupied Point: 1 50000.0000 50000.0000 100.00 Iron Pipe
Backsight Point: 2 50500.0000 50000.0000 100.00 Iron Rod
Backsight Direction: N 00d00'00" E
Backsight Distance: 500.00'
Pt# Angle Right Distance Northings Eastings Elev Description
100 90d00'00" 125.22' 50000.0000 50125.2200 100.00 Hub
113 90d00'00" 155.22' 50000.0000 50155.2200 100.00 Hub
125 90d00'00" 175.22' 50000.0000 50175.2200 100.00 Hub
Any help you can offer will be appreciated.
Nicholas, this should've been started as a new thread rather than tacking on to a thread that is only partially relevant.
I had actually started something like this years ago and got sidetracked so it never got completed. I looked at it again today, added in your thoughts on the output formatting, and think the result is useable. It should have some sort of error catching in case the user inputs invaild point numbers/ranges. But as long as the user is careful, it seems to work well. If the user enters a point that doesn't exist for either the Ocupied or Backsight points, it just exits. The stakeout is output to a file of the user's choice for a name, but I've hardcoded the path to be the same as the drawing. That could obviously be changed however you like.
One other thing to note....I don't think this will work with point numbers > 62,000 or so (limitations of the INT type in autolisp).
Jeff,
Thanks for the program, the one I began to create is very similar is structure. I know I should have started a new thread, and I will start one soon. I also run into the same issues your program does when it comes to Angle Rights. Unfortunately Autocad does not think like surveyors do, angles in AutoCAD and LISP always seem to return the accute angle and/or Left Angles (counterclockwise) instead of the angle turning to the right or (clockwise). In the stakeout result posted below the Angle Right should have been 225d0'0". I have explored trying to set ANGBASE to 90d00'00" so that North is 0d00'00" and tried to change ANGDIR to clockwise, however I still seemed to get the angle turning counterclockwise. Ultimately I believe the best solution is to convert the BS & FS Directions to Azimuths, by converting them to Surveyors Units to evaulate which quadrant each of them are.
Command: STAKEOUT
Occupied point number: 1
Backsight point number: 4
Point numbers to stake: 5
Filename for output: g:\lisp\txt.txt
------------------------Radial Stakeout---------------------------
PtNum Northing Easting Elevation Description
Occupied Pt: 1 1065.2199 1073.5198 8.76 IRON PIPE
Backsight Pt: 4 1065.2199 1560.5141 0.00 SET HUB
BS Direction: E
BS Distance: 486.99
Pt# Angle Right Distance Northing Easting Elev Description
5 135d0'0" 324.63 1294.7652 843.9745 8.99 SET HUB
; error: bad argument type: streamp nil
Command:
Thanks Jeff,
This worked perfectly and has set me on the right path to extract more info from cogo points.
Tyler Young
Jeff,
Is there a way to extract Civil 3D Labels to text or better yet Multileaders?
Thanks.
In case you know/do .NET API programming and have not noticed this:
http://drive-cad-with-code.blogspot.ca/2016/11/extract-autocad-civil3ds-label-text.html
Norman Yuan
