Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Layout Elements North Arrow
2 REPLIES 2
Marko^
844 Views, 2 Replies
My question is where are the North arrows found that are in the layout elements ribbon?
I would like to make a change to one of the north arrows but I can’t find where they are.
Another question I have. Can you make the north arrow dynamic to the scale of the viewport so they are a ratio to the scale of the viewport? Like a 2in. north arrow on a 50 or 100 scale and a 1in. on a 2000 scale location map.
2 REPLIES 2
tyronebk
in reply to: Marko^
I believe the all of the map symbols are being pulled form this folder:
%programfiles%\Autodesk\AutoCAD 2015\Map\Sample\Symbols\
Map - North Arrows.dwg  - should contain the north arrows
You could use reactors to change the scale of the north arrow block when the viewport changes scale. I remember having troubles detecting and reacting to all viewport changes when I attempted something similar in the past.
Marko^
in reply to: tyronebk
Thanks for your help.
Rail Community
