is there a possibillity to get the labellocation of a cogopoint in visuallisp.
I tried it with (vlax-get-property cogopto "LabelLocation") but the proprty Labellocation seems unknow (C3D 2012).
Has somebody an idea?
Thanks Robert
Solved by Jeff_M. Go to Solution.
Hello Jeff,
I have a polyline and cogopoints, the label of the cogopoints should be aligned to the polyline (this is possible with 'LabelRotation) and it should be possible that the label is above or under the line is positioned (the cogos have the same LabelStyle) and the user can decide where the label is postioned.
In the C3D 2013 API Idocumentation I see the property LabelLocation, do know is it in 2013 possible?
Thanks Robert
Hello Jeff,
thank you for the information.
Are the re two different APi - Reference- Guides for .Net and ActiveX? Where can I see which properties are exposed in ActivX?
Thanks Robert
