Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Label Group
3 REPLIES 3
joantopo
599 Views, 3 Replies
Label Group
Hi.
I would like to show all "Label Styles Sample Line" in a datagridview.
I have this, but how I get "LabelStylesSampleLineRoot"?
     Autodesk.Civil.DatabaseServices.Styles.LabelStylesSampleLineRoot estilosEtiquetas= civDoc. .................;
                    Autodesk.Civil.DatabaseServices.Styles.LabelStyleCollection collEstilos = estilosEtiquetas.LabelStyles;
Moreover, I want to show a checkbox column in datagrid to show if each style is added in Label Group Sample Line.
Autodesk.Civil.DatabaseServices.SampleLineLabelGroup
 Is it one group for each sample line or one group for the sample line group?
How can I get it?
I have been looking for in Sample line group object but I don´t find it.
In the case of Alignment, it has the method GetLabelGroupIds but it is OBSOLETE.
Perhaps, I had to look for in LabelGroup object but then, where is the Label Group sample line?
Thanks in advance.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
3 REPLIES 3
joantopo
in reply to: joantopo
I have seen  this method for Sample Line Group objects :
SampleLineGroup.GetAvailableSampleLineLabelGroupIds()
which returns an ObjectIdcollection.
However I don´t understand why Sample Line Group is able to have several Sample Line Label groups.
joantopo
 Autodesk.Civil.DatabaseServices.Styles.LabelStylesSampleLineRoot estilosEtiquetas= civDoc.Styles.LabelStyles.SampleLineLabelStyles;
                   for(int i=0;i<=collEstilos.Count-1;i++)
                   Autodesk.Civil.DatabaseServices.Styles.LabelStyle estil= trans.GetObject(collEstilos[i],OpenMode.ForRead) as Autodesk.Civil.DatabaseServices.Styles.LabelStyle;
                   string nombre = estil.Name;
                   ObjectId id = estil.ParentLabelStyleId;
quangpt.tric
Hi @joantopo,
Can we assignt Label Sample Styles foreach Sample Line?
Rail Community
