Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Initialize Civil 3D 2010 Object Model Error
6 REPLIES 6
967 Views, 6 Replies
I'm trying to run some VBA routines made for C3D 2009 in C3D 2010, but I'm
allways getting the error message:
Error: Unable to initialize Civil 3D Object Model
I'm sure it's a very basic question but can anyone help me we this?
Tks
Luis
6 REPLIES 6
Hello Luís,
I haven't used VBA in Civil3D (doing all .NET) but does your routine reference
a specific Civil3D version that might stop if from running?
> Hi,
> I'm allways getting the error message:
> Tks
> Luis
No it doesn't, it catches de version number before start it.
Tks
Luis
"Michael Robertson" wrote in message
news:6354148@discussion.autodesk.com...
Hello Luís,
reference
> Hi,
> Tks
> Luis
Hi Luis,
YOu need to:
Changes the references under [Tools][References] to suit R2010
You need to change the number 17.2 (for R2009) to 18 (for R2010) in the
GetCivilObjects code.
Lastly, save under a new name so you don't lose your R2009 functionality..
If that doesn't work, step through the code till you find the line
creating the error and post the line.
Laurie Comerford
Luís Laíns wrote:
> Hi,
> Tks
> Luis
Hi Laurie
Thanks for the reply. Unfortunely still doesn't work. It looks like the Set
g_oCivilApp = ... that itsn't workink but I can't understand the reason.
Here is the code:
Option Explicit
Public g_oCivilApp As AeccApplication
Public g_oAeccDoc As AeccDocument
Public g_oAeccDb As AeccDatabase
' Start Civil 3D, create document and database objects.
Public Function InitCivil3D() As Boolean
Dim oApp As AcadApplication
Set oApp = ThisDrawing.Application
Const sAppName = "AeccXUiLand.AeccApplication.7.0"
Set g_oCivilApp = oApp.GetInterfaceObject(sAppName)
If g_oCivilApp Is Nothing Then
MsgBox "Error creating " & sAppName & ", exit."
InitCivil3D = False
Exit Function
Set g_oAeccDoc = g_oCivilApp.ActiveDocument
Set g_oAeccDb = g_oAeccDoc.Database
InitCivil3D = True
End Function
Sub AlignHorizontalGeometry_RunReport()
On Error Resume Next
Dim rptDlg As ReportForm_HorizontalGeometry
' initialize C3D
If InitCivil3D = False Then
Call MsgBox("Error: Unable to initialize Civil 3D Object Model",
vbOKOnly, "Civil 3D Reports")
Exit Sub
Err.Clear
' Create report dialog and display it
Set rptDlg = New ReportForm_HorizontalGeometry
If Err.Number <> 0 Then
Exit Sub
rptDlg.Show
Set rptDlg = Nothing
End Sub
Luís
"Laurie" wrote in message
news:6354983@discussion.autodesk.com...
Hi Luis,
YOu need to:
Laurie Comerford
Luís Laíns wrote:
> Hi,
> Tks
> Luis
Hi Luis,
Your InitCivil3D code works in my R2010 environment and it is very
similar to the code I use.
Have you checked the references in [Tools][References]
You should be seeing:
Autodesk Civil engineering 7.0 Land Object Library
Autodesk Civil engineering 7.0 UILand Object Library
Also try the [Debug][Compile] command from inside the VBAIDE.
Laurie Comerford
Luís Laíns wrote:
> Hi Laurie
> Here is the code:
> Option Explicit
> InitCivil3D = False
> Exit Function
> End If
> InitCivil3D = True
> End Function
> Thanks
> Luís
Hi Laurie,
Once again ... You're right 🙂
The [Debug] [Compile] did it
Thanks a lot
Luís
news:6355333@discussion.autodesk.com...
Hi Luis,
Laurie Comerford
Luís Laíns wrote:
> Hi Laurie
> Set
> Here is the code:
> Option Explicit
> InitCivil3D = False
> Exit Function
> End If
> InitCivil3D = True
> End Function
> Thanks
> Luís
Rail Community
