Hi everyone
I created a Net dll plugin and successfully loaded in Civil 3d 2014 with NetLoad command, the plugin contains a ribbon bar with a ribbon button launching a dialog.., but when To be Loaded automatically (by AutoLoader) at startup it did'nt load, is there any way to make it load automatically at Civil 3d start up
here its my ContentPackage.xml
<?xml version="1.0" encoding="utf-8"?> <ApplicationPackage SchemaVersion="1.0" AppVersion = "3.0" ProductCode = "{E74E298D-D430-4100-83D0-CA230BB00A41}"> <CompanyDetails Name="ESOL Engineering Bureau" Phone=" " Url=" " Email="eng.ims134@gmail.com" /> <RuntimeRequirements Platform="AutoCAD|AutoCAD*" OS="Win32|Win64" /> <Components> <RuntimeRequirements OS="Win32|Win64" Platform="AutoCAD|AutoCAD*" SeriesMin="R19.0" SeriesMax="R19.1" /> <ComponentEntry AppName="SurfaceTool" Version="3.0" ModuleName="./Contents/SurfaceTool.dll" AppDescription="Surface Tools Plugin" LoadOnAutoCADStartup="True" /> </ComponentEntry> </Components> </ApplicationPackage>
and my Code (main file):
using System; using System.IO; using System.Collections.Generic; using System.Linq; using System.Text; using System.Threading.Tasks; using System.Windows.Controls; using System.Drawing; using System.Drawing.Imaging; using System.Drawing.Drawing2D; using System.Windows.Media.Imaging; //civil 3d assemblies using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.Windows; using Autodesk.AutoCAD.EditorInput; using Autodesk.Civil; using Autodesk.Civil.ApplicationServices; using Autodesk.Civil.DatabaseServices; using Autodesk.Civil.Runtime; using Autodesk.AutoCAD.DatabaseServices; //for ribbon controls using Autodesk.Windows; namespace SurfaceTool { public class SEXPORT: IExtensionApplication { Editor ed; [CommandMethod("ims_surf")] public void ims_surf() { SurfaceTool stool = new SurfaceTool(); stool.Display(); } #region Initializing and termination members public void Initialize() { //ed = appy.DocumentManager.MdiActiveDocument.Editor; //ed.WriteMessage("\n This is Created By ESOL Engineering Buruea \nType EXPS and hit Enter Key for using the tool"); ////throw new NotImplementedException(); //if (Autodesk.Windows.ComponentManager.Ribbon == null) //{ // //load the custom Ribbon on startup, but at this point // //the Ribbon control is not available, so register for // //an event and wait // Autodesk.Windows.ComponentManager.ItemInitialized += // new EventHandler<RibbonItemEventArgs> // (ComponentManager_ItemInitialized); //} //else //{ // //the assembly was loaded using NETLOAD, so the ribbon // //is available and we just create the ribbon // cr(); //} cr(); Autodesk.AutoCAD.ApplicationServices.Application.SystemVariableChanged += TrapWSCurrentChange; } private void ComponentManager_ItemInitialized(object sender, RibbonItemEventArgs e) { //now one Ribbon item is initialized, but the Ribbon control //may not be available yet, so check if before if (Autodesk.Windows.ComponentManager.Ribbon != null) { //ok, create Ribbon cr(); //and remove the event handler Autodesk.Windows.ComponentManager.ItemInitialized -= new EventHandler<RibbonItemEventArgs> (ComponentManager_ItemInitialized); } } //solving workspace changing public void TrapWSCurrentChange(object sender, Autodesk.AutoCAD.ApplicationServices.SystemVariableChangedEventArgs e) { if (e.Name.Equals("WSCURRENT")) { cr(); } } public void cr() { RibbonTab tab1 = CreateRibbon("ESOL Tool"); if (tab1 == null) { return; } RibbonPanelSource rpannel = CreateButtonPannel("ESOL Tool", tab1); if (rpannel == null) { return; } RibbonButton b1 = CreateButton("Surface Tool", "ims_surf", "SurfaceTool.SurfaceIcon.png", rpannel); //RibbonButton b2 = CreateButton("Profile Tool", "EXP1", "RibbonInCivil.Profile.png", rpannel); } public void Terminate() { //throw new NotImplementedException(); ed.WriteMessage("\n --------------------"); } private RibbonTab CreateRibbon(string str) { //1. Create ribbon control RibbonControl rc = ComponentManager.Ribbon; //2. Create ribbon tab RibbonTab rt = new RibbonTab(); //3. ribbon tab information assignment rt.Title = str; rt.Id = str; //4. add ribbon tab to the ribbon control's tab rc.Tabs.Add(rt); //5. optional: set ribbon tab active rt.IsActive = true; return rt; } private RibbonPanelSource CreateButtonPannel(string str, RibbonTab rtab) { //1. Create panel source RibbonPanelSource bp = new RibbonPanelSource(); //3. ribbon panel source information assignment bp.Title = str; //4. create ribbon pannel RibbonPanel rp = new RibbonPanel(); //4. add ribbon pannel to the ribbon pannel source rp.Source = bp; //5. add ribbon pannel to the tobs rtab.Panels.Add(rp); return bp; } private RibbonButton CreateButton(string str, string CommandParameter, string pngFile, RibbonPanelSource rps) { //1. Create Button RibbonButton button = new RibbonButton(); //3. ribbon panel source information assignment button.Text = str; button.Id = str; button.CommandParameter = CommandParameter; // name of the command button.ShowImage = true; button.ShowText = true; button.Size = RibbonItemSize.Large; button.Orientation = Orientation.Vertical; // from system.windows.controls //if(Utilities134.LoadPNGImageFromResource("logo.png") != null) // button.LargeImage = Utilities134.LoadPNGImageFromResource("logo.png"); //else // if (Utilities134.LoadPNGImageFromResource("rib134.logo.png") != null) button.LargeImage = Utilities134.LoadImage(pngFile); // 4. to add command to the button write the line below button.CommandHandler = new AdskCommandHandler(); //5. add ribbon button pannel to the ribbon pannel source rps.Items.Add(button); return button; } private RibbonButton CreateButton1(string str, string CommandParameter, string pngFile, RibbonPanelSource rps) { //1. Create Button RibbonButton button = new RibbonButton(); //3. ribbon panel source information assignment button.Text = str; button.CommandParameter = CommandParameter; // name of the command button.Orientation = Orientation.Vertical; // from system.windows.controls button.Size = RibbonItemSize.Large; //button.LargeImage = LaodImage("imageName.ext"); button.ShowImage = false; button.ShowText = true; //button.LargeImage = Utilities134.LoadPNGImageFromResource("logo.png"); // 4. to add command to the button write the line below button.CommandHandler = new AdskCommandHandler(); button.LargeImage = Utilities134.LoadImage(pngFile); //5. add ribbon button pannel to the ribbon pannel source rps.Items.Add(button); return button; } #endregion } public class AdskCommandHandler : System.Windows.Input.ICommand { public bool CanExecute(object parameter) { return true; } public event EventHandler CanExecuteChanged; public void Execute(object parameter) { //is from a Ribbon Button? RibbonButton ribBtn = parameter as RibbonButton; if (ribBtn != null) { string cmdName = (String)ribBtn.CommandParameter; // remove all empty spaces and add // a new one at the end. cmdName = cmdName.TrimEnd() + " "; // execute the command using command prompt Application.DocumentManager.MdiActiveDocument. SendStringToExecute(cmdName, true, false, true); } } } public class Utilities134 { //checking of Civil 3d existence public static bool IsCivil3D { get { return (HostApplicationServices.Current.UserRegistryProductRootKey.Contains("000")); } } public static System.Windows.Media.ImageSource LoadImage(string name) { BitmapImage bi = new BitmapImage(); bi.BeginInit(); bi.StreamSource = GetEM(name); bi.EndInit(); return bi; } public static Stream GetEM(string rname) { return System.Reflection.Assembly.GetExecutingAssembly().GetManifestResourceStream(rname); } //Native function #region PInvoke to avoid 'Not Responding' status /// <summary> /// Process Windows messages to avoid 'Not Responding' state /// </summary> public static void AvoidNotResponding() { Utilities134.NativeMessage msg; Utilities134.PeekMessage(out msg, IntPtr.Zero, 0, 0, 0); } [System.Runtime.InteropServices.StructLayout(System.Runtime.InteropServices.LayoutKind.Sequential)] private struct NativeMessage { public IntPtr handle; public uint msg; public IntPtr wParam; public IntPtr lParam; public uint time; public System.Drawing.Point p; } // We won't use this maliciously [System.Security.SuppressUnmanagedCodeSecurity] [System.Runtime.InteropServices.DllImport("User32.dll", CharSet = System.Runtime.InteropServices.CharSet.Auto)] private static extern bool PeekMessage(out NativeMessage msg, IntPtr hWnd, uint messageFilterMin, uint messageFilterMax, uint flags); #endregion } }
Solved by ebo134. Go to Solution.
We do the same thing via a custom startup shortcut that points to an script (scr) file that net loads the ribbon dll (make sure the path to the dll folder is in both the support & trusted folder variables).
In your startup shortcut use the command "/b c:\myfolder\startup.scr" (the /b switch stands for batch and runs the script)
In your script file you would have something like:
netload myribbon.dll
If your ribbon is loaded in your extension applications initialize method you are good to go, if your ribbon is loaded via a command then just add your ribbon startup command in the script.
I believe you may be able to do this via either CUI or ACad.lsp also but the scr way was easier to maintain and less likely to step on other profiles for our situation.
We prefer not to load our applications via auto-register/startup because they are specific to doing work for our deliveries and make no sense outside our profile.
thank you for your reply
but first I want to distribute my plugin in future, I need to know this method of loading of plugin (and its the best way)
second I do not know how to make this script in detail, please can you explain more about it or guide me through a resource link
thanks
I guess the first question, is your plugin designed for general C3D usage or should it only be used along with a specific profile?
If a specific profile you can use the script method I provided. A script file is just a text file with a .scr extension, the file just contains Autocad commands. You can point to the script file from a profile specific shourtcut.
I work for FDOT and our tools are programmed around using our specific resources and we don't want them loaded outside our profile so here is our profile startup command:
"C:\Program Files\Autodesk\Autodesk AutoCAD Civil 3D 2014\acad.exe" /ld "C:\Program Files\Autodesk\Autodesk AutoCAD Civil 3D 2014\AecBase.dbx" /p "C:\FDOT2014.C3D\Support\Profiles\FDOT2014C3D.arg" /b "C:\FDOT2014.C3D\support\profiles\fdot.scr" /nologo /nossm
The actual contents of our scr file is: (note the "fdotribbon" command at the end loads our ribbon).
netload layersync.dll
netload ADNPlugin-OffsetInXref.dll
netload AssemblyLabelToggle.dll
AssemblyLabelToggle
filedia 1
fdotribbon
If you want your program available for general use here's a "Through The Interface" article:
http://through-the-interface.typepad.com/through_the_interface/2006/09/automatic_loadi.html
Or you could use the Autoloader:
http://adndevblog.typepad.com/autocad/2013/01/autodesk-autoloader-white-paper.html
I would suggest to check this 'Autoloader' technology from Autodesk -
Does it help ?
Thank you guys, I solved my problem, I'd forgotten that I was comment out a part of my code:
this part of code is important for loading the ribbon at start up, and finally I commentted out a line after the code above which it is (cr();).
Now it works good
thanks
There is a little error in your even handler when you try to remove the event handler, I think:
To remove the _existing_ event handler, which is already created, you want this:
Autodesk.Windows.ComponentManager.ItemInitialized -= ComponentManager_ItemInitialized;
