Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
How to change type for existing Alignment?
10 REPLIES 10
Message 1 of 11
DZagorulkin
1078 Views, 10 Replies
Hello!
I need change type for Alignment with NET API. Alignment has property AlignmentType, but this property is read only!
In COM API Alignment not has this property. And with user interface to make it easy!
Any ideas?
P.S. Sorry for my english
10 REPLIES 10
Message 2 of 11
Partha.Sarkar
in reply to: DZagorulkin
Yes, I see AlignmentType is ReadOnly -
public Autodesk.Civil.DatabaseServices.AlignmentType AlignmentType { get; }     Member of Autodesk.Civil.DatabaseServices.Alignment
When you said this - "And with user interface to make it easy! " did you mean we can change Alignment Type using user interface tools / commands ? If So, could you highlight the tool / name of the command ?
Partha Sarkar
Developer Technical Services
Autodesk Developer Network
Message 3 of 11
DZagorulkin
in reply to: Partha.Sarkar
Thanks for reply!
EditAlignmentProperties --> first tab "Info" --> change value in popup list "Type" (my Civil is Russian, may be mistakes).
Message 4 of 11
DZagorulkin
Message 5 of 11
Partha.Sarkar
I have investigated this and also had a discussion with my colleagues from engineering team. I can confirm you this is not available through API, sorry. If you want, I can log a wish list for the same.
Partha Sarkar
Message 6 of 11
DZagorulkin
It is a pity! I wanted to write my application neatly in Civil 3D.
But it is not critical for me and my users. They agreed to the Alignment with the default type.
Thanks!
Message 7 of 11
paolo_serra
Any news on this topic? I'm facing the same issue in C3D 2017, thanks
Paolo Emilio Serra
Principal Implementation Consultant
Solution Innovation Lead
Global Consulting Delivery | Customer Success | Autodesk
Message 8 of 11
DZagorulkin
in reply to: paolo_serra
Message 9 of 11
paolo_serra
In this case I'd want to log a wish for it, thanks (and on COM too)
Paolo Emilio Serra
Message 10 of 11
DZagorulkin
Send it to ADN Dev HELP or Subscription center.
As I know Partha Sarkar does not provide support programmers more.
Message 11 of 11
joantopo
Give kudos to this idea:
http://forums.autodesk.com/t5/autocad-civil-3d-ideas/api-set-alignment-type-method/idi-p/6493693
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
Rail Community
