I can change it under structure properties, but I can't find where to change it before I make the pipe network
Solved by Jeff_M. Go to Solution.
These types of questions should be kept in the maon C3D forum, not the customization forum.
To answer the question, set a Structure rule to set 0 depth sumps, then make sure this rule set is applied when creating the network.
Guess I type too slow....glad you figured it out!
