I´m trying to use this user control (CheckBoxComboBox):
http://www.codeproject.com/Articles/21085/CheckBox-ComboBox-Extending-the-ComboBox-Class-and
I have checked other code, for example:
All codes, always with the same bug
I obtain this message (see the screenshoot).
I have already included the reference (accoremgd.dll) v 19.0.0.0
I believe that this reference is about Autodesk. I don´t understand why this user control need it?
What´s the matter?
Thank you.
Solved by Jeff_M. Go to Solution.
ok. I attachment it with a zip file, my project.
The problem is when a try to put this control in the typeviewercontrol (paletteset).
I choose it from the Component controls category and then, show that message.
I add attachment my project.
My project zip file:
http://depositfiles.com/files/cq0mqclf1
The CheckedComboBox control was intended (I believe) to be used in it's own Project. So by adding a project to your Solution, moving the code for the control to that project, adding all the required references for it, then building it, I could then reference that Project in the other Project and successfully place the control in your form.
I've saved the Solution (moved back into VS2010 format) to a Dropbox folder for you to download and see what I've done. https://dl.dropbox.com/u/32148252/DesignSurveyor.zip
Hope that helps you get back on track!
Great Jeff!!!
I have already understood the idea.
I have made the steps that you explain in my solution, and the control works.
Thanks.!!
