Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Getting the station and elevation from a profile view
4 REPLIES 4
dwcouch123
610 Views, 4 Replies
I am using LISP in C3D 2012.  I am trying to get the station and elevation of a point I pick in a profile view.  I found the Method that will get that info, but I can';t seem to get the syntax right.
 This is the Method;
HRESULT FindStationAndElevationAtXY(
    [in] double X,
    [in] double Y,
    [out] double * pStation,
    [out] double * pElevation,
    [out, optional] VARIANT * pInBounds
This is the routine I am trying but not having any luck working.
(defun C:getsta ()
  (setq ProfView (vlax-ename->vla-object (car (nentsel "\nSelect Profile View "))))
  (setq pt1 (getpoint "\nSelect Point "))
  (setq pt1X (car pt1))
  (setq Pt1Y (cadr pt1))
  (setq pstation 1.0)
  (setq pelevation 1.0)
  (vlax-invoke profview 'FindStationandElevationatXY (pt1x, pt1y, pstation, pelevation))
 Can someone help me get the syntax right??  Thank you,
Dave
4 REPLIES 4
Jeff_M
in reply to: dwcouch123
(vlax-invoke profview 'FindStationandElevationatXY pt1x pt1y 'pstation 'pelevation)
On vacation and can't verify, but may need to add the optional out param as well:
(vlax-invoke profview 'FindStationandElevationatXY pt1x pt1y 'pstation 'pelevation 'inbounds)
dwcouch123
Jeff, first of all, what are you doing checking the discussion groups when you are on vacation???
Next, thanks for the response.  I tried both variations, and other variable names.  The line seems to run with no errors, (I just get a nil as a response).  But pstation and pelevation are nil also.  Any other ideas?  Anyone else??
Dave
Jeff_M
Just killing time before heading off to the next segment of this trip. 🙂
You might try (vlax-invoke-method ....) instead of the shorter version.
dwcouch123
Jeff, obviously, the vacation isn't dulling your brain.  Adding the -method did the trick.  Thank you, now get back ot the vacation.
Dave
Rail Community
