Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Getting intersection of tin lines and a polyline
4 REPLIES 4
stacy.dunn
683 Views, 4 Replies
Is it possible to locate the xy coordinates of the intersection of a polyline and the edges of TIN lines on a surface?  I am looking for a way to programattically flatten a polyline to a surface and add vertices to it where they cross TIN lines.
Stacy
Stacy Dunn
4 REPLIES 4
Jeff_M
in reply to: stacy.dunn
In .NET: the SampleElevations() method takes a Curve.ObjectId as an argument and returns a 3dPointCollection of all the TIN or GRID intersections with that curve.
In COM: the SampleElevations method takes 2 points and returns any intersections found along the line between them. So as long as you pline has no arcs you could go segment to segment.
stacy.dunn
Jeff,
Thank you for the quick response and information.
Stacy
Stacy Dunn
Partha.Sarkar
in reply to: Jeff_M
And there are some relevant blog posts in IM DevBlog -
http://adndevblog.typepad.com/infrastructure/2012/04/want-to-use-only-startpoint-and-endpoint-as-inp...
http://adndevblog.typepad.com/infrastructure/2012/04/using-sampleelevations-in-autocad-civil-3d-2013...
Hope this helps.
Partha
Partha Sarkar
Developer Technical Services
Autodesk Developer Network
joantopo
in reply to: Partha.Sarkar
Great!! I will have to modify my own "maptrim"(vaciado areas) utiility because I created specifically a new feature line from entity(boundary) to do that using GetSurfaceIntersectPoints() method. Autodesk.AECC.Interop.Land.AeccLandFeatureLine oFtrLn = (Autodesk.AECC.Interop.Land.AeccLandFeatureLine)lineaCaract.AcadObject; Autodesk.AECC.Interop.Land.AeccSurface oSupLn = (Autodesk.AECC.Interop.Land.AeccSurface)sup.AcadObject; double[] punts = null; try { punts = oFtrLn.GetSurfaceIntersectPoints(oSupLn); } catch { }
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
Rail Community
