I am writing a program to get the daylight point offset from the baseline at every station on the applied assembly and i am facing two problems
- The station output is not sorted how can i get the station output be sorted in sequence
- The daylight point offset output is not the same offset drawn on the corridor drawing after checking Do you have any idea? I checked other pointcodes (E.g. EPS, ETW) and the offset values was right, the problem is only at the daylight points
Dim
opt AsPromptEntityOptions = NewPromptEntityOptions("Select a Corridor")
opt.SetRejectMessage("Object Must be a Corridor")
opt.AddAllowedClass(GetType(Corridor), False)
Dim a1 AsObjectId= ed.GetEntity(opt).ObjectId
Dim a2 AsCorridor = mytrans.GetObject(a1, OpenMode.ForRead)
MsgBox("Corridor= "& a2.Name.ToString)
Dim b1 AsBaseline = a2.Baselines.Item(0)
For
Each basereg AsBaselineRegionIn b1.BaselineRegions
For
Each **** AsAppliedAssemblyInbasereg.AppliedAssemblies
Dim p1 AsCalculatedPointCollection = ****.PointsByCode("Daylight")
Dim z AsInteger= p1.Count
if z <> 0 Then
MsgBox(p1(0).StationOffsetElevationToBaseline.X.ToString)
MsgBox(p1(0).StationOffsetElevationToBaseline.Y.ToString)
MsgBox(p1(0).StationOffsetElevationToBaseline.Z.ToString)
EndIf
Next
Next
Tamer Mourad
Get the FeatureLine from the baseline instead, it will come out in order. The feature line location should be correct.
Christopher
Thanks, but i still need it using point code because i will need daylightfill as well. Also i dont know why the offset output is incorrect. Do you have any idea?
The feature line extracts based on point code, so you shouldn't have any issues there.
