Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Getting all stations about transition from cut to fill or viceversa
1 REPLY 1
joantopo
336 Views, 1 Reply
Hi.
I would like to get a list of all stations from corridor which they are the transition station from cut to fill /or from fill to cut.
For example, for the "Intersection" feature line.
Do you know any ways to do this?
Thanks.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
1 REPLY 1
Civil3DReminders
in reply to: joantopo
You'd have to go through each of the baselines and then the regions and find the appropriate links and then track where the changes in elevation goes from up to down or down to up.
Not quite the solution, but a start:
http://adndevblog.typepad.com/infrastructure/2012/07/export-civil-3d-corridor-feature-lines-to-polyl...
Rail Community
