Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
get vertex from survey figures or parcels
6 REPLIES 6
joantopo
426 Views, 6 Replies
Hi.
I want to get vertex from survey figure or parcel.
I have seen this for feature line:
http://adndevblog.typepad.com/infrastructure/2012/10/getting-civil-3d-land-featureline-vertices.html
But "Autodesk.AECC.Interop.Land" doesn´t have AeccLandSurveyFigure.
How can I do it?
Is it necessary convert survey figure to polyline?
Thank you.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
6 REPLIES 6
stacy.dunn
in reply to: joantopo
Figures, feature lines, alignments and parcels inherit the AcDbCurve object.  You should be able to get the the vertices by accessing the Curve object in .net.
In lisp you can use the vlax-curve-getpointatparam function.
Stacy Dunn
joantopo
in reply to: stacy.dunn
Yes but:
 How I get Survey Figure from Interop?
joantopo
I´m trying this:
using (Transaction trans = db.TransactionManager.StartTransaction())
                        Autodesk.AutoCAD.DatabaseServices.DBObject obj = trans.GetObject(id, OpenMode.ForRead);
                        DBObjectCollection entitats = new DBObjectCollection();
                        SurveyFigure SF = obj as SurveyFigure;
                        if (SF != null)
                            // get the projected curve from SurveyFigure
                            Curve baseCurve = SF.BaseCurve;
 but "baseCurve" which is the property or method to get all vertex?
joantopo
With feature Line and Parcel, I can create a new polyline for each entity and then ,I can get all vertex from polyline.
Finally, I erase that polylines.
http://adndevblog.typepad.com/infrastructure/2013/04/creating-featureline-using-com-api-iaecclandfea...
However, with "Survey Figure" I can´t create a polyline
stacy.dunn
In the following blog post you can see how to  "Convert Civil 3D SurveyFigure to Polyline object" and then you can get the vertices from the polyline.
http://adndevblog.typepad.com/infrastructure/2013/01/convert-civil-3d-surveyfigure-to-polyline-objec...
Cheers,
Partha
Rail Community
