I've requested this before, so I'm kind of rechecking.
If I have a Corridor set up, and want to know the shape of the road section at a station along a baseline alignment, can
it be done via the API?
Normally, you would do this by cutting the surface created by a corridor, and looking at the profile, but that suffers
in horizontally curving areas. The problem is the user will pick points to label based on an arc, while the steep curb
surface "chords" behind the actual curb line.
I'm basically looking to get an alignment/assembly based TC elevation, if I pick a point on my curving curb line in
plan.
I guess I could dig through the corridor and find the region I was in, then dig through the assembly to see what is
going on in that region.
Is there a faster way to tell what region I am in, and what the section is doing there relative to the baseline that
defines it?
thx
James Maeding
Civil Engineer and Programmer
jmaeding - at - hunsaker - dotcom
