Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
get alignment object from data referenced corridor surface
1 REPLY 1
wang890
243 Views, 1 Reply
is it possible to get the alignment name which the corridor surface is built from when the surface is being data referenced. in other word no corridor as the middleman.
the way i see it is when corridor suface is referenced, it becomes a regular surface and loses some properties such as parent alignment.
i am still using COM. maybe .net can do it? either way works. so just please someone knows the code that would be very helpful. thank you.
Stantec
Dell Precision 5530, Prism M320PU, C3D 14/17/19
1 REPLY 1
Partha.Sarkar
in reply to: wang890
Did you try with IsReferenceObject or IsReferenceSubObject ?
If this doesn't help, could you upload a sample DWG file for me to check if this is possible with current set of APIs.
Partha Sarkar
Developer Technical Services
Autodesk Developer Network
Rail Community
