i need help making my north arrow rotate with the viewport if anyone can help me that would be awesome
Solved by jmartt. Go to Solution.
I've made a button that uses this LISP file.
I didn't write this. It was probably Sam Lucido.
(defun c:rn()
(setq tw(entget(car(entsel" Select a Viewport:"))))
(setq new (cdr (assoc 0 tw)))
(cond
((= new "VIEWPORT")(setq rt(cdr(assoc 51 tw))))
((= new "LWPOLYLINE")(setq temp (entget(cdr (assoc 330 tw))))(setq rt(cdr(assoc 51 temp))))
(setq en(car(entsel" Select North Arrow: ")))
(setq elist(entget en))
(setq elist(subst (cons 50 rt)(assoc 50 elist) elist))
(entmod elist)
(princ)
Can you provide more details on your request? It seems that you have a custom arrow (not a built in), am I right?
To keep an AutoCAD entity from rotating with the view, you'll need to override (in C++) or overrule (in .NET) the ViewportDraw behavior to maintain the entity position regarding the view direction.
There is a basic implementation for this in C++ at http://adndevblog.typepad.com/autocad/2012/06/how-to-control-an-entity-viewportdraw-so-that-it-alway...
Is that the direction that you need?
The built-in AutoCAD arrow is not on the drawing, but a different type of image...
If you need yours on the drawing, then you need to manipulate it, at least that's my understanding...
Steve Hill
Civil Designer / .NET Developer
AutoCAD Civil 3D Certified Professional
http://redtransitconsultants.com/
Autodesk Exchange Store
Twitter | LinkedIn
Please select the Accept this solution button if my post solves your issue or answers your question.
