Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Finding the specific Point
3 REPLIES 3
ebo134
493 Views, 3 Replies
Hi
I want to know is a point(for example p1) is on the right of an alignment?
can anyone help?!
Tags (1)
3 REPLIES 3
joshuamodglin
in reply to: ebo134
There is a StationOffset method in the Alignment object which, when fed the northing and easting, will provide, through referenced double variables, the station and offset. If the offset is negative, then you are to the left of the alignment.
HTH,
Josh Modglin
Advanced Technologies Solutions Logo
ebo134
in reply to: joshuamodglin
Thank you so much. its exactly what I want
Daniel.Du
in reply to: ebo134
If this post answers your question, would you please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Daniel Du
Developer Technical Services
Autodesk Developer Network
Rail Community
