I am trying to work a routine that will draw tangents with or without curve in a profile by calling the command in the Toolbar icon to "Draw Tangents" button that is on the Profile Layout Tools toolbar. I can't seem to locate the command that I could execute at the comand line or in LISP. Where can I find a complete list of C3D commands to reference??
Dave
Solved by Partha.Sarkar. Go to Solution.
Do you mean you are looking for the command which creates Tangent like the tool in "Profile Layout Tools" (Command : _AeccCreateProfileLayout) and there you have various options under Tangents ?
I don't see tools in "Profile Layout Tools" have equivalent command line version, but most of these functionalities are exposed in API.
In this case you could use -
ProfileEntityCollection.AddFixedTangent Method in .NET API
public ProfileTangent AddFixedTangent(
Point2d startPoint,
Point2d endPoint
Does it help ?
Thank you. I may end up using that, but for now, I found the "Sample" Create Profile VB program that ships with Acad. I think I can modify this to do what I want.
Dave
Hi Dave,
I am glad to help you here 🙂
Cheers,
