Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Finding out which Part Family the pipe is from
4 REPLIES 4
1050 Views, 4 Replies
I am updating a system which lists the sizes available for a specific part. What the client is looking for is to only show the sizes that have been defined in the parts list for the family that the part currently is associated with. This is where I am having difficulty. I cannot seem to locate what family the pipe is from.
Does anyone know of a .Net (I really would like to avoid COM if at all possible) to know which family the pipe belongs to?
4 REPLIES 4
Jeff_M
The PartFamily property is not exposed in .NET, as I'm sure you've found. But, you can get the PartFamily via late-binding so no COM references are needed.
        [CommandMethod("GetPartFamilyTest")]
        public void getpartfamily()
                        Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            PromptEntityOptions entOpts = new PromptEntityOptions("Select part: ");
            entOpts.SetRejectMessage("..Not a network part, try again.");
            entOpts.AddAllowedClass(typeof(PipeDb.Part), false);
            PromptEntityResult res = ed.GetEntity(entOpts);
            if (res.Status != PromptStatus.OK)
                return;
            using (Transaction tr = HostApplicationServices.WorkingDatabase.TransactionManager.StartTransaction())
                PipeDb.Part part = (PipeDb.Part)tr.GetObject(res.ObjectId, OpenMode.ForRead);
                object acadpart = part.AcadObject;
                object prtfam = acadpart.GetType().InvokeMember("PartFamily", System.Reflection.BindingFlags.GetProperty, null, acadpart, new object[0]);
                ObjectId prtfamId = DBObject.FromAcadObject(prtfam);
                PipeDb.Styles.PartFamily partFam = (PipeDb.Styles.PartFamily)tr.GetObject(prtfamId, OpenMode.ForRead);
                tr.Commit();
in reply to: Jeff_M
A concise, simple, and ingenious way to do it. I am running in between projects at the moment and won't probably be able to test the code before Friday but it looks pretty straightforward and will mark it as solution on Friday, once tested.
Impressive work Jeff! Thanks for sharing.
in reply to: Jeff_M
Tested, proven, works.
Thanks again Jeff.
I don't suppose there is a way of doing this in vb.net now? (for 2016)
Rail Community
