If I use this code it will give me the insertion point for a block
(setq ent (car (entsel "\nSelect Main Object: ")))
(setq InsPt (assoc 10 (entget Ent)))
Now if I try to use this for a surface label and try to get the insertion point
(setq oEnt (vlax-Ename->Vla-Object ent))
(vlax-dump-object oEnt)
I dont see anything that will help me get the insertion point. Is there some other sneaky way or utility function that can help me do this?
Help? 🙂
thanks a bunch!
dg
Not sure AutoLisp "sees" any property of a surface label like insertion point. It is possible though to get a surface label "location" property using .net api (Civil3D 2013 in any case). Spot elevation labels have only one "location" property, but it might be different with other labels (for exapmle surface slope label can have 2 such properties - "location" and "location2"). Check the api reference here:
http://docs.autodesk.com/CIV3D/2013/ENU/API_Reference_Guide/index.html
In case of spot elevation label you might be intrested in Autodesk.Civil.DatabaseServices Namespace -> SurfaceElevationLabel Class -> SurfaceElevationLabel Properties -> Location
