Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Featureline.MoveToSite() woes.....
2 REPLIES 2
Jeff_M
435 Views, 2 Replies
In an attempt to come up with a solution to Joan's need for a GetSplitCurves() for Featurelines, I have uncovered a quirk with the MoveToSite method. In order for new SplitFeaturelines to not be have their elevations affected by the original Featurline I create a Temporary Site which I move the original featurline to. I then edit the elevations of the new featurelines. All of this is working well, however when I use the MoveToSite() a second time to return the original featureline to the original Site I get a system argument exception when passing the original Site.ObjectId. Code to follow....
2 REPLIES 2
Jeff_M
in reply to: Jeff_M
No code...found a workaround by not using sites at all. First erase the f/l then unerase it after editing the new f/l's.
Partha.Sarkar
in reply to: Jeff_M
HI Jeff,
Looks like you have found out a work-around. Let me know if you need any further help here.
Partha
Partha Sarkar
Developer Technical Services
Autodesk Developer Network
Rail Community
