In an attempt to come up with a solution to Joan's need for a GetSplitCurves() for Featurelines, I have uncovered a quirk with the MoveToSite method. In order for new SplitFeaturelines to not be have their elevations affected by the original Featurline I create a Temporary Site which I move the original featurline to. I then edit the elevations of the new featurelines. All of this is working well, however when I use the MoveToSite() a second time to return the original featureline to the original Site I get a system argument exception when passing the original Site.ObjectId. Code to follow....
Solved by Jeff_M. Go to Solution.
HI Jeff,
Looks like you have found out a work-around. Let me know if you need any further help here.
Partha
