The whole Survey database is very accessible with ADO for reading (and
writing if you are prepared to reverse engineer the tables and fields that
need to be populated for a data entry item). Hence, adding data to it is
far simpler if you use the Autodesk supplied APIs.
It is quite easy to write figures and networks to the database. Without
looking at the Object Model, I can't remember if you can easily edit then.
I would expect that you could read a figure out of the database - delete it
and write two new ones back
Regards
Laurie Comerford
"Jeff Mishler" wrote in message
news:5902687@discussion.autodesk.com...
With VBA it's not easy, at least in 2008 and below. With lisp or .NET you
can use the the curve class of the Autodesk Geometry API to get them. With
lisp, that's (vlax-curve-*...). For .NET, search for posts from early last
year, or late 2006, by myself &/or sinc, regarding Featurelines..
2009 exposes featurelines to the API, not sure about figures, though.
HTH,
Jeff
"bmcanney" wrote in message news:5902486@discussion.autodesk.com...
> Does anyone know how to extract vertex information from a Feature Line or
> a survey Figure object?
> The entlist for a feature line looks something like this, and figures are
> very similar:
> ((-1 . ) (0 . "AECC_FEATURE_LINE") (330 .
> ) (5 . "1088E") (100 . "AcDbEntity") (67 . 0) (410
> "Model") (8 . "P-TOPO-BRAK") (48 . 0.8) (100 . "AecDbEntity") (102 .
> "{AEC_SUBOBJECT") (300 . "AeccImpFeatureLine") (100 . "AecImpObj") (3 .
> (100 . "AecImpEnt") (171 . 0) (100 . "AeccImpEnt") (102 .
> "AEC_SUBOBJECT}")
> (102 . "{AEC_NULLOBJECT}") (100 . "AeccDbEntity") (100 . "AeccDbFeature")
> (100
> . "AeccDbFeatureLine"))
> The data must be somewhere, but I have no idea how to get at it.
> Thanks!
> Brent McAnney
