I'm trying to create an expression to label a LinkLength in my section view. I only want the label to show if the LinkLength is greater than zero. Our subassembly for a ditch bottom width targets a polyline, and the label style dimensions correctly, however, of we choose to use a V bottom ditch in that area by setting the link width to 0, the label style shows 0. I'd like to set it up to not show at all if the width is set to 0. See attached pic. My current label style has line components, but I can certainly change that if required.
Solved by andrewpuller3811. Go to Solution.
