Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
export selected by a polyline points
0 REPLIES 0
Message 1 of 1
247 Views, 0 Replies
Hello everyone:
 I have a problem, I need to modify a lot of points COGO and this must first export them to a .txt file, to do this create a polyline that encloses all points separating points so I should not change.
 To do this modifying a lisp routine that had the problem is that when you are exporting items not save my selection but exported me all the points, I tested that the selection of points if it works, replacing the "_exportpoints" by "_move" and so move only the selected points.
 any help? Here I give the code:
;;Rutina para seleccionar entidades dentro de polilinea,arco,spline
(defun c:poly_sel()
(prompt "\nSelecciona la Polilinea")
(setq coord(pl_plist (car(entsel))))
  (command "_EXPORTPOINTS" "_wp")
  (foreach pt coord
          (command pt)
  (command "" "" )
    (defun PL_plist ( ename / en entl flag vlist pt Elev sa ea Rad CenPt );;función para obtener coordenas de una entidad
    (setq
       vlist '()
       entl   (entget ename)
       en     (LI_item 0 entl)
    (cond
       ((= en "LWPOLYLINE")
          (setq
             vlist '()
             Elev   (LI_item 38 entl)
          (foreach pt entl
             (if (= (car pt) 10)
                (setq vlist (cons (list (cadr pt) (caddr pt) Elev) vlist))
          (setq vlist (reverse vlist))
       ((= en "SPLINE")
          (setq vlist (LI_mitem 11 entl))
          (if (not vlist)
             (setq vlist (LI_mitem 10 entl))
       ((= en "POLYLINE")
          (setq
             ename  (entnext ename)
             entl   (entget ename)
             en     (LI_item 0 entl)
             vlist '()
          (while (= en "VERTEX")
             (setq flag (LI_item 70 entl))
             (if   (and
                   (zerop (logand flag 1))
                   (zerop (logand flag 2))
                   (zerop (logand flag 8))
                   (/= flag 128)
                (setq
                   pt (LI_item 10 entl)
                   vlist (cons pt vlist)
             (setq
                entl  (entget ename)
                en    (LI_item 0 entl)
       ((= en "LINE")
          (setq vlist (list (LI_item 10 entl) (LI_item 11 entl)))
       ((= en "ARC")
          (setq
             CenPt (LI_item 10 entl)
             sa    (LI_item 50 entl)
             ea    (LI_item 51 entl)
             Rad   (LI_item 40 entl)
             vlist (list (polar CenPt sa Rad) (polar CenPt ea Rad))
       ((= en "3DFACE")
          (setq vlist (list
                      (LI_item 12 entl) (LI_item 13 entl)
    vlist
    (defun LI_item (n alist)
       (cdr (assoc n alist))
 greetings and thanks for answering !!!
0 REPLIES 0
Rail Community
