Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Export Civil3D pipe network with Object Data to Shapefile(SHP)
2 REPLIES 2
raghulan
1216 Views, 2 Replies
Hello Ppl,
 Any advice on how to export Civil3D pipe network with Object Data as Shapefile.
Any code snippets will be of great help.
cheers
Raghulan Gowthaman Cert IV TAA, B.E,.
Senior Technical Consultant | Developer - R&D
A2K Technologies Sydney
Web : www.a2ktechnologies.com.au
www.civil3dforum.com | www.e4forums.com
www.zcodia.com.au
www.raghulangowthaman.com
2 REPLIES 2
Partha.Sarkar
in reply to: raghulan
There's no API to achieve this directly. You might have to create an AutoCAD entity from Civil 3D Pipe object which will have the Object Data attached. After that you can use ManagedMap API to export to SDF or SHP format. You can see some relevant code snippet in our ADN DevBlog :
http://adndevblog.typepad.com/infrastructure/2012/04/export-dwg-to-sdf-using-autodeskgismapimportexp...
http://adndevblog.typepad.com/infrastructure/2012/03/exporting-dwg-to-sdf-using-epf-file-using-map-3...
http://adndevblog.typepad.com/infrastructure/2012/03/how-to-use-command-line-version-of-mapexport-fo...
Partha Sarkar
Developer Technical Services
Autodesk Developer Network
raghulan
in reply to: Partha.Sarkar
Thanks Partha,
There isnt much available for map3d and civil. I have seen those posts and I worked around it.
but the problem is ...I cannot get the geomtry data of the pipe from the api. i can only get the geometry data of autocad objects but not civil3d objects....how to go about it...cheers..
www.zcodia.com.au
Rail Community
